Remove ignition switch?
Old Nov 15, 2013 | 07:26 PM
tinman52's Avatar
tinman52
Welder User
Can't get the ignition switch to release on the '65.....I push it in, it starts to turn, but no joy. What am I missing? How far does it need to turn to release? Prefer not to break anything.....
Thanks in advance.
Old Nov 15, 2013 | 09:27 PM
fivestarmmd's Avatar
fivestarmmd
Got tumbler out?
Old Nov 15, 2013 | 09:35 PM
tinman52's Avatar
tinman52
Welder User
Originally Posted by fivestarmmd
Got tumbler out?
No. Does it need to come out first? If so, how?
Old Nov 15, 2013 | 09:42 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Put the key in the ignition and turn it to the left as far as it will go. Then get a straight pin and push it gently into the little tiny hole just beneath the key in the tumbler face and turn the key a little further left until it stops again and the tumbler can be pulled out.
Factory service manual has pictures I can scan if you need. I assume it's the same as '66...
Old Nov 15, 2013 | 09:44 PM
fivestarmmd
Turn key to acc, Take small pointed object as paperclip stick in small hole and turn key to left and pull out. When installing tumbler stick back in and turn right.
Old Nov 15, 2013 | 10:50 PM
tinman52's Avatar
tinman52
Welder User
OK, thanks! Now I just need to find the key.........
jimlj
Mar 27, 2018 05:42 PM
66 twin i
Sep 16, 2009 10:20 AM
kjvforme
Aug 15, 2009 11:12 AM
raveng60
Bronco II
Nov 29, 2006 06:48 AM
flydadmcw
Electrical Systems/Wiring
Jul 16, 2003 06:32 PM
