ignition switch
Old Feb 21, 2013 | 10:27 PM
beckman's Avatar
beckman
ignition switch
hi everybody i am having an issue with a 1986 ford econoline van and when you turn the key to crank the engine over it cranks extra long but when you release the ignition switch it fires right up is that a problem with the ignition switch i think so any help would be great thank you
Old Feb 21, 2013 | 10:44 PM
ctubutis's Avatar
ctubutis
What engine?
Do you know what kind of ignition system it has?
Old Feb 21, 2013 | 10:55 PM
beckman's Avatar
beckman
302 and just a standard ignition system
Old Feb 21, 2013 | 11:22 PM
ctubutis's Avatar
ctubutis
For ignition system, I mean either a DS2 or TFI.
Does your distributor have a black or gray module on it with about 6 wires going to it? Is it EFI?
Old Feb 22, 2013 | 08:41 PM
beckman's Avatar
beckman
carburetor
Old Feb 22, 2013 | 09:55 PM
1983F1503004x4's Avatar
1983F1503004x4
An '86 with a 302 and a carburetor should be a Motorcraft 2bbl with a TFI computer controlled ignition and carb, if memory serves as it should.
Long cranking times and it firing up after you let the switch go makes me think that your timing is off. It could also be your choke isn't functioning correctly or problems with other components on the motor, etc.
Best thing to do is pull codes from the computer and see what it says is going on.
'78F250351m
Mar 4, 2015 08:32 PM
86ford302help
Dec 8, 2011 06:47 PM
vioc22
Jun 11, 2004 02:58 AM
