Stacking tuners
Old Jan 30, 2007 | 09:45 PM
gungho351's Avatar
gungho351
Stacking tuners
I have the edge juice right now, I keep hearing about this DP tuner, I'm just wondering if I can put the DP in the PCM, since the Edge juice doesn't use that slot. Also I was wondering where the PCM number can be found at, mine had a tuner in it once before, and has part of the plastic cut away
Old Jan 30, 2007 | 09:49 PM
John311t's Avatar
John311t
Do not stack the Edge Juice with a DP chip. There is no reason to stack chips for more power. The PCM number is located on the side of the computer, you need to pull it to get the number.
Old Jan 30, 2007 | 09:52 PM
gungho351's Avatar
gungho351
Thanks for the info John
Old Jan 30, 2007 | 09:54 PM
MAKO314's Avatar
MAKO314
Jody at Dp can get your pcm code from your vin# also
John311t's Avatar
John311t
When jody burns ur chip, he can do everything the edge can do and make it 10X better. Stacking chips can be bad on the 7.3.
Old Jan 30, 2007 | 09:57 PM
gungho351's Avatar
gungho351
i'm going to jody right now, gonna order it. Hope you don't feel guilty john.
Old Jan 30, 2007 | 09:58 PM
gungho351's Avatar
gungho351
know anybody wanting a Edge?
Old Jan 30, 2007 | 10:02 PM
MAKO314's Avatar
MAKO314
make sure you get the 140 "smoke" tune it's the sh#$ you said you wanted smoked rice didn't you
Old Jan 30, 2007 | 10:05 PM
John311t's Avatar
John311t
Feel guilty for what, im getting a jodys tunes soon here. Just need to fix other problems first.
gungho351's Avatar
gungho351
I smoke rice already, can't wait to get it
Old Jan 30, 2007 | 10:10 PM
John311t's Avatar
John311t
I like it when i pull up next to the honda with the big 5" tach. They like to laugh when asked to race, until their window is full of smoke and they are seeing the pintle hitch.
Old Jan 31, 2007 | 03:51 PM
Hello's Avatar
Hello
I stacked my Predator 100hp tune with the DP. It doesn't matter what you programed in in the PCM because whatever is in the PCM will be overridden by the DP chip. I just wanted it in there in case I have to pull the chip out. Can't stand the weak stock PCM tune.
Old Jan 31, 2007 | 04:04 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I filled a coworker's window with smoke this morning on the way to work....it was beautiful sight.
UNTAMND
Apr 7, 2010 05:54 PM
JBARRBQS
Apr 6, 2010 09:52 PM
Dmax Stroked 00
19
Jul 27, 2008 11:35 PM
floridadude
Apr 10, 2008 04:12 PM
97 HD
20
Nov 7, 2007 07:02 PM
