Alternator conversion
Old Jan 30, 2007 | 04:25 PM
olewilly's Avatar
olewilly
I have an 77 F-100 that the alternator has just gone south on me, I would like to convert from the old external regulator type to an internal regulator alternator.
Can this be done, and if so how?
Thanks!
Willie...
Old Jan 30, 2007 | 05:25 PM
FordGuy1280's Avatar
FordGuy1280
yeah you can, all that you have to do is to get a one wire alternator. they have a internal reg, higher amps and all that you have to do is run a wire form the alt to the battery. you can get rid off all of the other wiring that was involved with the external regulator. you can serch around on the internet to find one that fits the engine that you have and for a price that you want, remember that with alternators, you get what you pay for. the reason that I say that is that some of them are pretty expensive but they are good alternators. There should be others on here who can recamend a good one to get
Old Jan 30, 2007 | 05:37 PM
unrulee's Avatar
unrulee
By all means go 3g. Do a search for how. Go to a junkyard and look for a first gen Taurus with a 3.8, it'll bolt right, it's cheap (I paid $35), it'll put out 130amps, and doing the wiring for it is cake. Even though a person can do it without I used a wiring kit from http://pa-performance.com/.
It's one of the best mods I've done.
Old Jan 30, 2007 | 06:35 PM
mhg's Avatar
mhg
check out
www.fordfuelingection.com
for the way to wire up the 3g alt
Old Feb 1, 2007 | 02:48 AM
olewilly's Avatar
olewilly
Thanks!
Old Feb 2, 2007 | 09:14 AM
teds74ford's Avatar
teds74ford
3g vs gm
I have a quick question about the 3g vs gm. I did the 12SI gm. At the time, I didn't know about the 3g swap. Is there an advantage to the 3g over the gm?
As far as what is involved with the gm, you need a wire to the starter solenoid and if you have the 3 wire, like mine, you need to splice the plug into the hot wire and one to the guage in the truck.
Old Feb 2, 2007 | 10:30 AM
Franklin2's Avatar
Franklin2
Electrically no. There might be some mounting differences I do not know about though.
Old Feb 3, 2007 | 11:12 AM
teds74ford's Avatar
teds74ford
Thanks. So the main reason people do it is to keep the ford "ford"?
Old Feb 3, 2007 | 03:45 PM
Franklin2's Avatar
Franklin2
Yes, that's a lot of the reason. Sometimes Ford didn't use Ford alternators in the early days when they didn't make one big enough.
three.on.the.tree
Feb 7, 2016 10:24 PM
mattparham1
39
Sep 26, 2013 12:27 PM
i-w
Aug 5, 2011 09:31 PM
ktz78
Dec 20, 2010 11:10 PM
cubster
1983 - 2012 Ranger & B-Series
Oct 11, 2001 10:35 PM
