I have a new alternator thats been tested and voltage regulator. I have no current coming out of the alternator, does anyone know the proper wiring hook up
Ok tankyou im gunna start working on it here in a few minutes, ill keep you up one how its going. Ive also got window regulators, weather stripping, universals, and interior to do today......
Ok some im gunna get the alt going today nuts im running into some issues with that wiring diagram IASF is the order mine VR is in but I is my orange and black and goes to the batt+, A is yellow and goes to the batt post one the alt, S is green ans im assuming goes to the gaugr cluster, and F is orange with green trace and goes to the field post. also I have the S post one the alt going too my electric choke on the carb.
Ok one revision playing with the harness a bit more I noticed I is vacant, A has two wires in it slod yellow and orange and black.also the green is in the S post like I said but goes to a factory plug ghat goes up too the dash. I dont know if that makes a diffrence or not, if not ill go ahead and start cutting
Ok its the stock plug as far as I can tell there are no splices other than ones I did and it says ford (just redoing crap oem splices ), and I compared the new vr with the old one and bottom up they are both IASF. Its an 82 if that matters.
..... I don't know how else to explain this after post #7.
The schematic in post #2 is correct.
Green dash wire to I (you will not get anything unless this is connected)
Yellow A to alternator output (along with the orange/black fusible link going to the battery)
Your F (orange /green) seems to be connected correctly to the F of the alternator.
The S from your regulator needs to connect to the Stator of the alternator regardless of the wire color. (plus the choke should draw power too)
If the regulator plug is wired incorrectly just move the pins around in their sockets.
Ok im trying to check a few yards here in town and see if I can find a plug that is correctly wired some I can just change it out and dont have and ugly mess of mangled wires, thats all im trying too avoid. And I cant pull the pins out the plastic is some brittle I fear ill break it. Its funny stuff never goes back as easy as it came apart.
