Sponsored by: Real Truck
Front wheel ABS connector
Old Jan 30, 2007 | 11:52 AM
aLMOSTNORMAL's Avatar
aLMOSTNORMAL
Hi People,
I hope someone here can help me locate a part that the dealer said could NOT be bought seperately. I had a blow out in my 2002 PSD 4x4 that took out the ABS wires. The connector that comes from the wheel unit is new but the connector that attaches to the main harness is damaged. The markings are: on the ABS unit side are 30F1 Made in Mexico...and the harness side connector has EPC 13 on it. I need to get the connector from the harness as well as a couple of the socket pins. I have temporarly spliced the two wires together and the ABS system works fine...I just want to have the body shop put it back properly ( waterproof / removable ) so i can remove the unit without cutting the wires each time. Thanks, Mike
Old Jan 30, 2007 | 01:05 PM
aLMOSTNORMAL
Originally Posted by aLMOSTNORMAL
Hi People,
I found more writing embossed on the part: FOVB 14A459.
Old Jan 30, 2007 | 01:44 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
WELCOME to FTE!
Try a junkyard, that would be my first stop...
It's probably possible to get this part, PM discountfordpart if he doesn't join in the thread.
Old Jan 30, 2007 | 01:47 PM
krewat's Avatar
krewat
Hmm... looks like I got that name wrong... I'll look around for the right one.
Old Jan 30, 2007 | 02:13 PM
aLMOSTNORMAL
Thanks Krewat,
I will try the junkyards. But if you locate the name i would appreciate that also. Mike
Old Jan 30, 2007 | 02:47 PM
redford's Avatar
redford
Send PM to y2kfordparts
Old Jan 30, 2007 | 03:41 PM
krewat's Avatar
krewat
Musta changed his moniker - thanks redford!
Old Jan 30, 2007 | 08:06 PM
aLMOSTNORMAL
Thanks
THANKS A MILLION GUYS!! I went to the junkyard and salvaged a good one. It is installed and works great. Simple solution but I was locked into new and never thought about used..Thanks for the y2kfordparts address I am sure to use it in the future. Mike
Old Jan 30, 2007 | 09:41 PM
krewat's Avatar
krewat
That's great news... The best place for dealer-only stuff is the junkyard. And these Superduty's aren't old enough yet to all be completely wornout hulks rusting away in the weeds...
remotevirus
Dec 14, 2021 11:21 PM
GoldCo
Electrical Systems/Wiring
Jun 23, 2017 07:15 AM
GoldCo
Jun 22, 2017 07:59 PM
lovemy150's
May 25, 2016 08:30 PM
blee1ash
Mar 8, 2011 11:55 AM
