Help!
Old Jan 25, 2007 | 06:25 PM
  #46
jt559's Avatar
jt559
yea i drove it around an got it nice n warm. it fired right up after it was warm/ didnt have to give it any throttle at all. where is that switch located? how can i test it? also would a dirty fuel filter cause this? its wierd.. it only fires on full throttle. someone here local said something about the throttle position sensor
Old Jan 25, 2007 | 06:34 PM
  #47
Tenn01PSD350's Avatar
Tenn01PSD350
The IVS is part of the throttle pedal assembly along with the throttle position sensor IIRC. Unfortunately, I don't think it cares whether the engine is hot or cold so I would pretty much rule that out.
A dirty filter can cause serious starting problems, though the giving it throttle thing has me puzzled. Again, change the filter and make sure it has fuel pressure. Then check the HPO reservior level. I would think your prblem is one of those. If you don't change the filter, you have not eliminated one of the first fuel system problem areas and are stabbing around.
Perhaps the added throttle is causing it to apply more oil pressure to the injectors bringing the weaker fuel pressure up to enough to start.
Old Jan 25, 2007 | 06:37 PM
  #48
mrfixit64857's Avatar
mrfixit64857
Tenn, can this be the pedal assembly problem?
Old Jan 25, 2007 | 06:55 PM
  #49
Tenn01PSD350
Of course it "could" be. But why would it care to work properly after the truck has been warmed up? That is what puzzles me. It is not wired such that it looks at the oil temp as far as I know.
I will be working tonight so I have to get ready here soon. Perhaps amiller can check the pinpoints for the TP assembly for any link to cold starts or temp related issues when he gets on. If not, I will look for it tomorrow.
Old Jan 25, 2007 | 07:07 PM
  #50
Uzumati's Avatar
Uzumati
OK here is a little recap
Oil - 1000 miles
Oil Level - ??
Glow plugs - ??
Cranking Voltage - ??
CPS - Tach Moves
Fuel Pressure - ???
Codes - ???
What are the results from any of the test ??
Being a Cali Truck the Code could be a GP Circuit or you may not have fuel pressure or you may not have oil pressure or it could be weak batteries.
I have not seen the TPS/IVS referenced in any of the Hard/No Start pinpoints
Old Jan 25, 2007 | 07:27 PM
  #51
Kwikkordead's Avatar
Kwikkordead
I don't think a throttle assembly problem will prevent the engine from starting. But it will just sit there and idle with the check engine light on.
I think that's what it would do. I would have to go home, unplug my throttle assembly and try it out to verify. Maybe someone else with thier truck nearby could do the same and get back to us?
Old Jan 25, 2007 | 07:42 PM
  #52
jt559's Avatar
jt559
oil level is up. the tach moves when cranking. its getting over 10.5 volts at crank not sure how to test the glow plugs or the pressure. im going to change that fuel filter tomarrow hopefully if i can get a chance. i didnt check the hpop. i got frustrated with the truck an left an came back here. i will go back out in the morning when its light out. it confuses me as to why itl only start with full throttle. an why when its warm it will fire right up with no throttle. could the pump be going out?
Old Jan 25, 2007 | 07:50 PM
  #53
Tenn01PSD350
Yes, the pump could be going out. Change the filter, check the HPOP oil level while you are there(first thing before starting it), then see what happens.
Also: AGAIN what are your outside temps?
Does it smoke when it first starts and if so what kind?
How did it run? Did it get better as you drove it?
I know you will probably go right back out there and try to start it first thing but I advise against this until you check the aforementioned.
Old Jan 25, 2007 | 08:03 PM
  #54
jt559's Avatar
jt559
it only does this sometimes witch is odd..itl start up an run good for a couple days to a week. an then do it again. outside temps have been mid 20's at night an now are in the 60;s durin the day. no smoke. it ran great when it fired.
Old Jan 25, 2007 | 08:18 PM
  #55
Uzumati's Avatar
Uzumati
This is probably going to take a trip to a capable scan tool to isolate if it is not what tenn has suggested or glow plugs. Alot of sensors and factors have to come together in a very short time to crank a diesel like these, intermittant issues are very difficult to find.
Use 30*F as a break point and see if it has more trouble colder that that.
Old Jan 25, 2007 | 08:55 PM
  #56
jt559's Avatar
jt559
alright. it ran fine today.. i just dont get it.. its frustrating an if its electrical.. wel im not very good with it. im good at motors.. im good with tools. but electrical isnt my thing
embry1123
Feb 11, 2011 05:50 PM
choptop60
Mar 28, 2009 09:30 AM
interceptor1
20
Oct 31, 2006 05:22 PM
LYTSPID
Jul 15, 2006 09:27 PM
DT 466Man
Sep 6, 2004 09:11 PM
