6 CD changer jammed
Old Jan 19, 2007 | 08:30 AM
fred_79f250's Avatar
fred_79f250
6 CD changer jammed
Gentlemen,
I have the factory 6-CD changer in my 2000 EB Expy. The cartridge won't come out. When I press the eject button, I can hear the motor turn, some gears engage, the cartridge makes a little sideways movement, then all stops with no ejection, and if the stereo is on a little message lights up on the panel that says "ejection error".
Looking down between the narrow space around the cartridge, I don't see any CDs half-way engaged. I tried waving a wire back and forth in that space, and nothing's there.
I've tried inserting a hook to pull at the same time as it tries to eject - no luck. It's tightly held in there. I've tried pressig on the cartridge in different directions to see if it'll free from something, but no luck. And I've loked evryewhere for a manual ejection ejection button (usually hidden inside a hole for a wire), but don't see one.
Any suggestions??
Thanks.
Old Jan 19, 2007 | 12:52 PM
Garff's Avatar
Garff
If you can not get it out, look on Ebay and there is a company in Ca. that will repair it for around $90-$100. I sent mine in last year and had it back in 2 weeks and it worked great. The changer is easy to take out of the vehicle. Sorry I can't remeber the name of the company but just look in ebay for a Ford Expy changer and you will see their listing for repairs. Good luck
Old Jan 19, 2007 | 05:16 PM
Randy B's Avatar
Randy B
Originally Posted by fred_79f250
Gentlemen,
Any suggestions??
Thanks.
If it's not stuck in play mode, you can take a thin metal file or ruler, and slide it under the magazine from right to left. This should cause the ejection of the magazine. If it is in play mode, the magazine will not eject and you will have to take apart the unit.
Randy B
Old Nov 21, 2021 | 07:11 PM
gtq838's Avatar
gtq838
for my 06 navigator the issue was a loose ribbon cable
Here is a repair video I made. Not sure if it is the same for yours.
Kansas Man
Oct 19, 2018 04:26 PM
vinny8
Oct 24, 2011 03:35 PM
sixpointer10
Aug 16, 2004 03:31 PM
dgri134
Aug 20, 2001 10:36 PM
ematson
Aug 1, 2001 08:53 AM
