Just got this 6 disc cd player off Ebay. Did not get a manual with it and can't figure out how to get the discs to load. Keep getting cd error or slot full message. Anyone know the trick to loading this player or did I get a bum player? Thanks, Brent
I had a 6 changer in my 2001 Ranger, all you need to do is hit the load button and the door should open.
Also there may be cds in there already. There were six circles 1-6 on the display which indicate if you have a disc in the slot. to remove hit the eject button.
The unit may have been dropped in shipping or it could be a bad unit. I would take it apart if you can and look for the drive motor then see if you can turn it by hand. I read somewhere that some models have a shipping screw which must be removed to release the cd carrier.
Thanks, I'll try that. I tried everything else that would make sense and followed the instructions in my truck manual but screen says "slots full" when I hit load and it goes blank when I hit "eject" and hit the button to select which cd to eject. Thanks a lot.
Sounds like you might have a bad cd player. Did you try just taking it to a stereo install place. They have dont simple fixes for me for free. Good luck!
