Sponsored by: Real Truck
Adding OEM brake controller
Old Jan 18, 2007 | 05:11 PM
ag-ford-4x4's Avatar
ag-ford-4x4
I know people have done this. Im looking at a rough guesstimate of what this costs....installed or if i install it myself (if possible).
Old Jan 18, 2007 | 06:08 PM
Deluxe05's Avatar
Deluxe05
One of the site sponsors had the entire kit listed, I believe it was around $600. It included the master cylinder assembly, controller, etc. Once all of that is installed, you will need to have a dealer program the PCM; I do not know exactly what the programming difference is.
Old Jan 18, 2007 | 07:00 PM
rmblaster's Avatar
rmblaster
I paid around $450 for the kit. I installed the controller in the dash myself didnt want to pay dealer for that simple job and had the dealer install the new master cyclinder and reprogam the instrament cluster cost was about $200 The cluster needs to be programed so the truck knows that there is a controller installed and because thats where you see the warning messages pop up in the message center
Old Jan 18, 2007 | 09:55 PM
ag-ford-4x4
How is the OEM different (better or worse) than a brake controller like say the Prodigy??
Old Jan 18, 2007 | 10:23 PM
c.f.moore's Avatar
c.f.moore
I have used the Prodigy and the OEM controller on the same 5th wheel(14k#'s). The Prodigy was in a '94 F250 PS, the OEM in a '05 F350 6.0. The Prodigy was far superior to other aftermarket controllers that I'd used, and did a good job on the 34' Fifth wheel. I got the '05 w/OEM controller.
A few weeks later I had the "opportunity" (someone in a Toyota pickup trying to pull a U-Haul trailer out of control) to "panick" stop the '05+fifth wheel on I-5 on a down grade. I was extremely impressed with new '05 brakes, the controller, and the trailer brakes. I went from 65mph to 0mph in approx 200'. Not a single tire locked (felt like some of the trucks ABS control effected the trailer brakes) and the whole setup stayed perfectly in line.
Depending on what, how often, and where you tow the extra money for the OEM is justified.
Old Jan 19, 2007 | 08:08 AM
ag-ford-4x4
OK. Thats what i thought. Mostly i want it to be good, and its nice that it 'goes' with the truck. Why do you need a new master cylinder with the OEM Factory kit? None of the aftermarket ones come with a new cylinder, so i was curious.
Old Jan 19, 2007 | 08:12 AM
redford's Avatar
redford
FTE Leadership Emeritus
The OEM controller works off brake line pressure, measured at the MC.
Old Jan 19, 2007 | 09:17 AM
ccerniglia's Avatar
ccerniglia
Thumbs up
Part Numbers 5C3Z 19H332-BA(6.0L or gas with DRW) or 5C3Z 19H332-AA (gas with SRW) List Price $505.67. You'll have to quote Service on an installed price.
Old Jan 19, 2007 | 10:35 AM
wiingnut's Avatar
wiingnut
I have used the Prodigy and the OEM controller and like the OEM better. Though the Prodigy by far is the best aftermarket out there. Both are also made by the same company.
Old Jan 19, 2007 | 12:43 PM
ag-ford-4x4
WOW. I called three service departments and two gave me decent prices on installing the MC and PROGRAM, but the other said it can't be done. The service manager then proceeded to tell me it cannot be done. I politely informed him that it could and that they should check into it, because they probably turn away good business telling them it can't be done when FORD says it be done and sells a kit to do it.
Old Jan 19, 2007 | 12:53 PM
johnnysF350's Avatar
johnnysF350
I cant blame you for wanting the factory controller, I have it in my truck and I love it. I will add a vote for the prodigy as well though. I had one in my '03 and it was by far the best aftermarket out there.
Old Jan 19, 2007 | 02:36 PM
ccerniglia's Avatar
ccerniglia
I can't Believe that. I'm Sitting here at my Desk at Crowley FORD in CT in the Parts Department and i could ask almost every Tech, Counterman, or Service advisor and more then 95% of them know about or how to install or the Part number of the Factory brake controler. Sound like you should steer clean of that place, i wonder if they even know what a ford is.....
Old Jan 19, 2007 | 03:59 PM
ag-ford-4x4
yeah, i just told them that it can be done. Im not letting them do anything. If they dont think it can be done, then obviously, they are not qualified to do it.
Old Jan 19, 2007 | 04:19 PM
EnviroCon's Avatar
EnviroCon
Someone correct me if I'm wrong, but didn't Tekonsha (Prodigy) design the Ford ITBC?
I use the Prodigy myself ('cause I own an archaic '04 SD, so OEM is not an option), but the Ford unit is one of those rare OEM devices that people who use them swear by over an aftermarket equivalent. Go figure!!!
Old Jan 19, 2007 | 05:20 PM
blockmanjohn's Avatar
blockmanjohn
Will the Ford unit work with a manual transmision equiped truck?
jonkoby
6.4L Power Stroke Diesel
May 20, 2011 05:09 AM
skysoldier69
Nov 6, 2009 09:29 PM
Geof
1983 - 2012 Ranger & B-Series
May 19, 2006 09:44 AM
DeckedoutF150
Computer Chips & Tuners
Jan 31, 2006 03:57 PM
BSHORT
1997 - 2003 F150
Feb 1, 2005 08:43 AM
