Sponsored by: Auxito
Steering Stabilizer Install
Old Jan 27, 2005 | 02:42 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Has Anyone Installed A Steering Stabilizer On Their 97-03 4x4? I Was Wondering If It Was A Straight Forward Install Or Something Better Left To Someone With Experience In Suspension?
Old Jan 27, 2005 | 06:20 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Nobody Has Done This?
Old Jan 27, 2005 | 10:48 PM
Racerguy's Avatar
Racerguy
I'm guessing that a steering shock isn't a common addition on these trucks as it generally shouldn't be needed.
Having said that, most steering shocks are easy to install. Just a few bolts.
Old Jan 31, 2005 | 05:24 PM
JAYW's Avatar
JAYW
Steering Stab.
I put one on my 97 f150 4x4 a couple weeks ago to help with the 285/16 i put on.Its real easy.Hardest part was to take the bolts out of the idler arm and add a bracket there.Tolk about an hour for the whole job.Good luck
Old Jan 31, 2005 | 10:31 PM
Racerguy's Avatar
Racerguy
What brand of kit did you install?
Old Feb 1, 2005 | 08:42 AM
JAYW's Avatar
JAYW
Steering Stab
I installed a Rancho rs5000,Youve also got to buy a bracket kit to go with,shock about $45.00,kit was about $40.00.IT has a large bracket to bolt to the frame using the same bolts as the idler arm,comes with longer idler arm bolts.
Old Feb 1, 2005 | 08:43 AM
Racerguy's Avatar
Racerguy
Thanks for the info
stufarmer
Dec 26, 2016 11:42 AM
WidowMaker13
Apr 8, 2015 11:22 AM
chrismd188
Feb 14, 2014 09:11 AM
GreenballsFX4
Aug 12, 2012 06:40 PM
kaipo
Apr 25, 2006 03:29 PM
