Block Heater Confusion
Old Jan 17, 2007 | 09:42 PM
BD15's Avatar
BD15
I'm sure for many of you this is an old question but I have been unable to find the answer. I have a 97 F250 2 wheel drive 7.3 PSD. Through my reading on the internet it has been stated several times that all PSD's have a blockheater you just need to find it.
Well I have stopped looking unless I'm looking in the wrong location. From the information posted on the internet it appears that there are 2 possible locations. One in a freeze plug and the other is just above the oil filter. I have looked above the oil filter and there is a plug installed. I think I have looked at all of the freeze plugs and I do not see anything that would look like it.
This truck came from Texas so I'm assuming the previous owner never needed to use the heater. I have read that if the motor was replaced at some point with a new long block that it would not have a block heater, fact or fiction I don't know.
So maybe someone can finally answer the question, Where exactly should it be? This answer will also tell what I need to buy to install one.
Thanks in advance for your help.
Brad
Old Jan 17, 2007 | 10:13 PM
andy's 96' 250's Avatar
andy's 96' 250
i would start by looking for the plug to plug it into 110 A/C. mine is a 96 psd 2wd and it is located at the front driver side of the engine compartment. between the framerail and the power steering pump i think it runs back from there between the PSP and the fraimrail to the side of the pan. i'm not sure about the exact location where it enters the motor
Old Jan 18, 2007 | 07:40 AM
utahcrew's Avatar
utahcrew
BD15, I have a 1997 f250 4x4 and mine is located right by the oil filter (on top). crawl under your truck and look. I hope this helps. Good luck.
Old Jan 18, 2007 | 08:31 AM
ruger761's Avatar
ruger761
The block heater on the 97s was optional. I have a 97 and had to add one to a freeze plug next to the oil filter. Got it from advance auto parts online. Was about $20 if I remember correctly. But its a good idea to get new anti-freeze since it will drain out of the freeze plug anyways. Its kinda hard to get the block heater to seat correctly in the block. Oring is very tight.
Old Jan 18, 2007 | 10:07 AM
Brians97F250Crew's Avatar
Brians97F250Crew
yea ... roll under your truck and look up towards your oil filter. If you see a bright orange cable plugging into the oil cooler just above the filter then you have one. If there isn't anything plugged in there the heater may be installed but there is no cable. Then all you'd need to get is the wire. Hope this helps.
Old Jan 18, 2007 | 09:08 PM
RLC2269's Avatar
RLC2269
I found my 110 plug between the breather box and quarter panel all coiled up nice and tight. not sure if you are looking for plug or actually trying to find the heater. good luck.
Old Jan 18, 2007 | 10:33 PM
BD15's Avatar
BD15
Thanks for the info everyone. I think rugar761 might be right that it was an option that was not installed. I have been concentrating on looking for the heater itself, I figured if I found that then I could trace the cord to the plug. The location above the filter where it is suppose to be has a pipe plug installed. I believe on the 97 model year that this is where it was suppose to be installed but is not.
Old Jan 19, 2007 | 03:25 AM
Tazzmann's Avatar
Tazzmann
BD15, also try looking above the starter, the passenger side to the rear of the block. thats where mine was factory installed.
Old Jan 19, 2007 | 10:27 PM
andy's 96' 250
try checking the vin decoder, it might tell you if it was a selected option
idiabuse
Nov 29, 2014 01:26 PM
Wisconsinman
Jan 15, 2013 06:38 AM
ttexastim
Dec 8, 2010 11:12 AM
Jetsfan68
Modular V10 (6.8l)
Jan 1, 2006 03:19 PM
