can i get the coolant info a gain cant find forum and what type of fluid do u guys recommend for axles, transfer case is a borg warner, and transmission
a dana rear end takes a 90 weight gear oil that meets ford specs of eswm2c105-a whatever that is. It is a ford "premium rear axle lubricant". I think it can use a 80w-90 also if it meets the same spec.
