ok guys besides my expedition i have a 1989 ford bronco that i am fixing up but i have a problem ever since i put heders on the truck she ran fine for two years i had a problem with the rear axe and she sat down for over six months , i fix that and then she was having problems staying runing i had to put the egr valve and i put a buch of littler hoses that the guy that put the heders eliminate ok. to make the story short now the truck you step on the gas you hear the engine but is moving very slow she has a 351 engine on her ...couple of people told me that is a vacum problem , other people told me that the hedders were excaping air and thats why she was not running like she us to can someone please help me on this i dont want to get rid of the truck this was my first car and i really want to fixed .. any help will be gratly appriciated .. thanks ..
pull codes www.fordfuelinjection.com will show you how. check plug wires making sure they didnt melt onto the header. pull plugs and inspect if its been awhile give it a full tune up an double check the timing should be at 10*btdc with spout connector removed. do you hear any exhaust leaks, spray carb cleaner around the vac lines with the truck running to find vac leaks
"you step on the gas you hear the engine but is moving very slow"
Hmmm....
Did you remove/replace the serpentine belt? I have put on a serpentine belt that was one size too big and the motor sounded ok but gave the illusion that it was rotating slowly because of the pulleys were going slower.
Check your tensioner, it should be around <45 deg angle, not 80-90 deg.
ok guys something different now i was driving arround and my bronco shut off .. i went the next day and i started up and she turn on but then when i put the truck in drive she shuttoff and did not start at all any help will be good thank you
by the way anybody that knows a good bronco mechaninc in PA ...
