1st time diesel owner
Hi guys, just bought a 2002 F250 crew cab 4x4 lariat 7.3L auto. This is my first diesel and was just wondering what kind of regular maintenance, tips, or things to look for when owning a diesel. As far as I can tell the truck is stock, I did notice the catilytic(sp?) converter has been removed but other than that I don't think anything else has been done. I bought the truck from a local Dodge dealer so they were not much help and it did not have the owner's manual with it. I have heard that Ford puts a governor on them to keep them from going over 85mph, is this true? If so then my truck has been altered in some way because it easily goes over 90mph and still has some left.
What are good ways to get better gas mileage CHEAP?
Oh the truck has about 93,xxx miles on it.
One other thing I can't figure out is my cigarette lighter and over head compass are not working. I checked the fuses and they are not getting power, anybody know where else to look?
Thanks, Chris
Thanks, Chris
I use 15qts of Rotella 5w-40syn and motorcraft filter every 5000 miles. My blackstone reports say I should go 7000 miles so im going to be trying that this time around. I have the factory glove box manuals, haynes, and soon the Helms DVD. But I found just about all the info I ever needed off this site. As for mods most people go, intake, exhaust, gauges, and chip.
OK, my truck is an 01 and has less miles than yours but more importantly has no cats and never did. Yours may or may not have had cats.
There is no way to get great mileage really cheap aside from driving your truck off of a cliff and getting air time mileage. The truck weighs upwards of 4 tons depending on the model. Poke around though and see how you can improve your mileage.
As for your overhead compass and lighter, if you have checked your fuses, what can I say except "are you sure you checked the right ones"?
While an owners manual is far from encompassing, I always insist whoever sells me my new/used vehicle provide me with one. It is usually Ford and they always give me what I want.
Edit: Ohhh, I forgot to mention that I use Rotella 15-40 year around.
Originally Posted by Tenn01PSD350
OK, my truck is an 01 and has less miles than yours but more importantly has no cats and never did. Yours may or may not have had cats...
There is no way to get great mileage really cheap aside from driving your truck off of a cliff and getting air time mileage. The truck weighs upwards of 4 tons depending on the model. Poke around though and see how you can improve your mileage..
As for your overhead compass and lighter, if you have checked your fuses, what can I say except "are you sure you checked the right ones"?.
Hurricane,
Your truck wasn't equipped with cats. So you don't have to worry about that.
The fuse for the lighter is the same as the OBD-II connector, so check that one. Also check the one for the overhead display. It's best to check by swapping out the fuses instead of just a visual inspection.
Also the overhead display can go bad. I can't remember off hand right now, but there is a switch or capacitor that is prone to burning out on the board itself. If you have any small electronics skills, you can repair it yourself. If not, the replacement unit is over $200.
For oil I use Rotella Synthetic 5w40 year round. Definately comes in handy in the winter time. Cold starts are much much easier than 15w40. With a proper oil analysis, you can (if you choose) extend your oil change intervals. I change mine every 8K miles. I firmly believe that changing oil, no matter what kind, at 3K miles is a waste on our trucks. I'm sure others will disagree, but that's 15 quarts every few weeks, and it can get expensive for no additional gain or protection. Quite a few folks change theirs every 5K miles.
Diesel specific maintenance includes changing the fuel filter every 10K-15K miles, and changing the tranny fluid and filter every 30K or so. Other maintenance items are pretty much the same as a gas powered truck (grease fittings, differential, etc.) The coolant on 2002 trucks is the gold kind, good for 100K miles. You're almost ready for a flush there, same with the differentials. Good news is, you don't have to replace spark plugs. Glow plugs are only replaced when they go bad.
BTW, I have the same year and model truck as you, with the same mileage. Welcome, and enjoy your truck.
Owners Manual
Thanks, Chris
Thanks, Chris
Walt
http://www.genuineservice.com/genuineservice/en/gloveboxresults
If you want you can download an owners manual from https://www.fleet.ford.com/default.asp look under the maintenance tab.
Dont forget "blue Juice" every 6 mos fw 15 or what ever they use today. test strips can be had many places otherwise use of the proper coolant with whatever additives.
International is cheaper for the engine parts (because, well,,,, they just are) need proper IH part # which can usually be had with a search on this site.
