Rear Diff Swap
Old Jan 7, 2007 | 08:16 PM
StevensPoint's Avatar
StevensPoint
Rear Diff Swap
I'm planning to swap out my open carrier with a limited slip. The job looks pretty straight forward - is there anything I'm missing?
1) Remove cover, drain fluid.
2) Remove bolts at hub and slide axle shafts out a little.
3) Unbolt the carrier bearing retainers and pull out the differential.
4) Swap ring gear and put a new timing ring on new diff.
5) Installation is reverse - don't forget the limited slip additive.
Does anything need to be done with the pinion gear in the process?
Any advice is appreciated.
Old Jan 7, 2007 | 08:39 PM
barebackjake's Avatar
barebackjake
you will have to make sure the gear mesh is still where it needs to be. also need new preload spacers on the sides of the bearings to keep the bearing preload correct.
if you have that many miles on it i would put a new ring and pinon and bearings in it if there still original.
if you do replace the r&p get the factory ford ones there the only gears that are worth anything and timken bearings.
Old Jan 7, 2007 | 10:51 PM
fishmanndotcom's Avatar
fishmanndotcom
yea you'll need to reset the gears which is a prety tedious job, set aside an afternoon and make sure you have your dial caliper, torque wrench, and pinion depth tool as well as your standard everyday tools
it'd bout be just as easy to swap in the whole rear axle if you have another
-cutts-
Old Jan 8, 2007 | 07:04 AM
Cuda_jim's Avatar
Cuda_jim
Check out this site for good tips:
http://www.ring-pinion.com/HowTo.aspx
You don't need to remove the pinion gear unless you are replacing the pinion seal or bearings. The pinion depth won't change even if you did remove it. If you do remove it use a dial type inch pound wrench to get a pre-load on the pinion. Take the reading with everything else removed from the diff. The reading should be ~ 10 in lb with an old seal and bearings and ~ 18-20 in lb with a new seal & bearings.
The carrier preload (shims) can be tricky but with a little patience it can be done. You will need a dial indicator with a magnetic base. You are looking for ~.010 back lash on the ring gear. Start with the shims that where on the old carrier. Be sure to keep the shims in the location they came from. If you need to add or replace the shims with a different size you will need to determine the size needed and get them from a local diff rebuilder. They usuall have all sorts of shims
Old Jan 8, 2007 | 07:32 AM
StevensPoint
Great - Thanks for the advice
Old Sep 2, 2007 | 02:34 PM
StevensPoint
Thanks for all the advice. The swap was quite simple. Fortunately the backlash was where it needed to be when I put the posi in. Having to reset the backlash would have added a bit of time.
Thanks again.
Old Sep 2, 2007 | 02:38 PM
c00nhunterjoe's Avatar
c00nhunterjoe
9 times out of 10 i never have to reset side shims, i even swapped the 10.25 carrier in mine to a superduty 10.5 and reused the bearings that were on it and had to change nothing, backlash and gear wear pattern were perfect as was preload
Old Sep 2, 2007 | 03:13 PM
kawa's Avatar
kawa
Thanks again.
Happiness is a "Tight Posi"
Old Sep 2, 2007 | 04:52 PM
c00nhunterjoe
if possible get a superduty 10.5 posi, it is much heavier duty then the 10.25 posi,
price it new from ford, sometimes you would be surprised, the last time i checked a new 10.25 was only 250. but here is what the 10.5 looks like.
rather then have the typical guts, it is a 2 piece housing, containing a 3-pinion planetary set-up vs the stocker spider gear set-up, it has almost twice the clutches that a 10.25 has and weighs almost twice as much too. best part.....it drops right in, re-use your ring gear, bearings are the same too
Old Sep 3, 2007 | 08:12 AM
Cuda_jim's Avatar
Cuda_jim
Joe, I tried to rep ya on this one. Gotta spread the love around first. I'm doing mine the next time around. I have one question though, I have an open carrier. Will the switch still be that easy?
Old Sep 3, 2007 | 09:05 AM
c00nhunterjoe
let yours fall out, bolt the new one in, piece of cake, the hardest part is lifting the new one in, she is heavy. i can spin posi with the 35's on dry pavement, and if i lay on it hard around a corner and it hits 2nd, she will slide around
Old Sep 3, 2007 | 09:26 AM
tjbeggs's Avatar
tjbeggs
Jim I swapped out my open for a 10.25 LS carrier (couldn't find any 10.5's when i wanted it!) and my back lash and contact pattern were great. just don't mix up the side shims and you should be good to go. But definately check it all before you button it up.
Old Sep 3, 2007 | 10:44 AM
1997F-350's Avatar
1997F-350
so how much are you saying a sd ls carrier is? you definitely got my attention. i need to do this bad. gear swaps are new to me. what other parts am i looking at needing to buy also?
Old Sep 3, 2007 | 10:57 AM
c00nhunterjoe
i dont know how much a sd carrier goes for new from ford, i would hit the junk yard, just swap your ring gear and tone ring and thats it
Old Sep 3, 2007 | 11:00 AM
1997F-350's Avatar
1997F-350
sweet i am pretty stoked about this. i hate my open rear diff. thanks man
