77 F100 Auto Column Shift problems
Old Jan 6, 2007 | 10:23 AM
ron65's Avatar
ron65
Can anyone tell me how the column shifter works? My problem is when i picked up my truck from the paint shop. they had broken the column shifter inside the truck. so I am unable to shift the gears inside the truck. I removed the broken column shift sleeve and while i wait for the new one. i still cant get the linkage outside to move when I turn the shift tube inside the column. Would it (or could it) have also broken further down inside the column or does the shift sleeve have to push the tube down to engage the linkage outside?
Thanks for any help.
Ron.
Old Jan 6, 2007 | 02:18 PM
73f350sc's Avatar
73f350sc
Theres an arm near the bottom of the column just the other side of the firewall that connects to a linkage on the tranny itself...could have come off there or even on the tranny....do a search for posts about columns I know Dennis has put up some diagrams in the past of how it all goes together. Also if youcan find a Chiltons manual they have pics that help too. Also dont forget..if your trying to move it w/ the tube...you have to mimick the moevment of the selector as well ie push up or pull down on all the stuff that needs moved haha.
-Chris
Old Jan 6, 2007 | 02:22 PM
Mil1ion's Avatar
Mil1ion
The linkage is actuated by the arm at the bottom of the column
The shifter cowl is easily replaced on a standard column.
Old Jan 6, 2007 | 04:06 PM
ron65's Avatar
ron65
thanks for the replys guys, everything is hooked up and working under the hood.
75BigBlock
Dec 16, 2016 07:42 PM
Shane Carruth
18
Jun 14, 2016 05:05 PM
muth_33
Apr 28, 2016 05:43 PM
dozzman
Apr 18, 2016 09:59 PM
jlasater
37
Nov 28, 2014 10:18 PM
