Hooker Header fitment problems-PLEASE HELP
Old Jan 6, 2007 | 01:26 PM
CSwank's Avatar
CSwank
Has anyone installed full length headers on their 351M. I am in the middle of installing these headers.
LINK
1979 F-150 351M
On the passenger side, in order to match the header up , it looks like I'm going to have to dent in or modify the firewall/ floor pan. Also the driver side collector ends up directly under the transmission pan, and im wondering if this could cause some overheating of my auto trans. I was wondering if maybe they sent me the wrong headers or are these things typical of this installation. PLEASE HELP ASAP, as my truck is in pieces until I figure out what to do. If someone has pictures of their install done that would be great. Thanks
Last edited by Torque1st; Jan 6, 2007 at 04:46 PM. Reason: fixed huge huge link maybe
Old Jan 6, 2007 | 01:52 PM
petes79f150's Avatar
petes79f150
Welcome to FTE, CSwank. If you don't get an answer here, you might try posting your question in the 335 Series forum. I'm sure they would have the answer. While you're there, check out the forum sponsor's (TMyer) website.
Pete
Old Jan 6, 2007 | 03:08 PM
Mil1ion's Avatar
Mil1ion
Did you click the checkmark link to view all the truck info this set fits.
It has a yes & No section on application.
I would be more worried about Going thru starters as the headers will end up right beside the starter and ruin them with a heat shield.
Old Jan 6, 2007 | 03:33 PM
bucks77ford's Avatar
bucks77ford
You should not have to modify your truck that much to get the headers to fit. I did notice a couple different applications. One set for 4x4 and 4x2, also different for tranny application manual or automatic. I'm figuring you have the wrong application.
Old Jan 6, 2007 | 04:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check your cab mounts also. If they are rusted out the cab will set to low and interfere with parts fitment. Those headers are for a 4WD application.
Big Sky Highboy
Mar 4, 2013 10:59 AM
stilkikin
Feb 12, 2012 09:08 AM
2002fx4122
44
Nov 24, 2011 03:36 PM
fluffykins
24
Jun 2, 2011 03:02 PM
