Can I upgrade to automatic climate control?
Old Jan 5, 2007 | 06:18 PM
donoteat's Avatar
donoteat
Talking Can I upgrade to automatic climate control?
I have a 06 F350 XLT that comes with the standard heater and a/c *****. The Lariat style comes with dual-zone automatic climate control.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Is it possible to install the automatic climate control in my XLT?
<o></o>
Thanks
Old Jan 5, 2007 | 07:45 PM
Ultramagdan's Avatar
Ultramagdan
Most of the wiring harnesses are the same in the trucks. Some plugs used and others are not but a dual climate system might be a bit different.
Old Jan 6, 2007 | 02:59 PM
Steina's Avatar
Steina
CO River Rat
If I remember right, someone in the Explorer Forum priced out the parts to do this on an '04 XLT awhile back; along with over $1100 for hardware (new), the labor required was pretty extensive. Apparently there's a lot more involved than just changing out some dash controls.
Steve
Old Jan 6, 2007 | 07:15 PM
donoteat's Avatar
donoteat
I found some posts relating to this topic.
The bottom line is it would make more sense to buy a new truck if i want climate control.
thanks for the responses.
Old Jan 6, 2007 | 08:39 PM
Steina's Avatar
Steina
CO River Rat
Yeah, unless you have lotsa time and $$$ and plan on keeping your truck forever, it isn't a practical update.
Steve
Old Jan 8, 2007 | 03:35 PM
hhott71's Avatar
hhott71
Automatic Climate control is actually a downgrade.
When its so easy to twist the **** yourself if you are cooking or sweating.
Old Jan 15, 2007 | 07:52 AM
eysham's Avatar
eysham
for that matter, the only I find thing missing in the manual climate control is the leaver that changed the air intake from the outside to recieving circulated air from within the cab.
Is there a way to hack this somehow to avoid breathing trafic smoke??
eysham.
smoky israel
Old Jan 15, 2007 | 10:11 AM
Steina's Avatar
Steina
CO River Rat
Eyesham -
Unless the export F-350s are different, you've got a recirc setting on your controls. Do you have the Owner's Guide?
Steve
Old Jan 15, 2007 | 12:32 PM
eysham's Avatar
eysham
nop, no recirc setting/leaver/button.
just standard heater and a/c ***** like i see in all the pics in the US ford F-350 XLs
Old Jan 15, 2007 | 02:13 PM
Steina's Avatar
Steina
CO River Rat
I think MAX A/C will give you recirculation.
Steve
Old Jan 15, 2007 | 02:15 PM
eysham's Avatar
eysham
it will, but then it will be a cold cold winter...
any hacks to make it work with heater?
Old Jan 15, 2007 | 02:24 PM
Steina's Avatar
Steina
CO River Rat
You could install a switch in the A/C compressor clutch circuit, or just unplug it for winter.
Steve
Old Jan 16, 2007 | 01:35 AM
eysham's Avatar
eysham
but apart from turning the A/C on, the "MAX A/C" also cancels the temperature control ****, meaning that if i unplug the compressor, maybe it wont blow freezing A/C air, but i wont be able to bring on the heat...
eysham
Old Jan 16, 2007 | 11:38 AM
Steina's Avatar
Steina
CO River Rat
Yeah, I forgot that in MAX A/C the valve that allows coolant flow to the heater core is shut off by vacuum (in my Explorer anyway). Hopefully, a HVAC expert will chime in here with a way to get recirc for you.
Steve
Old Jan 17, 2007 | 01:31 AM
eysham's Avatar
eysham
i'll wait...
at least over here it is warm 3/4 of the year...
eysham
clarkbre
Apr 28, 2014 10:40 PM
pmibach
1983 - 2012 Ranger & B-Series
Apr 3, 2011 07:21 PM
KRH1326
Mar 3, 2011 03:55 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
pyro2nite
Dec 1, 2007 09:00 PM
