Sponsored by: Auxito
Temperature Control
Old Jan 5, 2007 | 03:38 PM
Bassgod's Avatar
Bassgod
Temperature Control
I have a 99 F-150, 2WD, 5.4L Super Cab. The temperature control for my ac/heat is going crazy. When I have it on heat, it will blow cold air most of the time. It will warm up occasionally, but then go cool again.
The opposite when I use my AC. It will blow cold air for awhile, but it seems like if I hit a bump, or stop at an intersection, the air will go hot and stay that way.
There really is no pattern that I can figure out, it just gets hot or cold when it wants to.
When I rotate the temperature **** it feels normal, except occasionally it will feel like it skips about a third of a turn, I notice this because all friction on the **** goes away and then comes back. I can rotate the **** back in the direction it came from and it will feel fine, but it will have no affect on the temperature coming out of all the vents.
It does it from all vents, defrost, floor, panel, etc..
Any suggestions would be greatly appreciated.
Old Jan 5, 2007 | 03:57 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Sounds like a broken Blend door in the duct work.
Old Jan 5, 2007 | 04:25 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE Bassgod.
Three things come to mind with what you described.
  1. As LxMan said, broken blend door.
  2. Could also be a broken temp control ****. Try switching the temp **** for one of the other control *****. These ***** tend to crack adn therefore won't grip the shaft properly to turn it.
  3. Finally, there is a vacuum line that comes through the firewall to supply vacuum to the controls. If this line is cracked, leaking air, then the sysptoms that you are having could occur as well.
Good luck!
Old Jan 5, 2007 | 04:54 PM
steve(ill)'s Avatar
steve(ill)
vacuum controls more of the direction the air goes--- defrost or floor. the two most common problems are as KR said, the **** could be stripped and spinning on the shaft, or the blend door arm is broken (or its motor stuck).
Old Jan 5, 2007 | 04:55 PM
Bassgod's Avatar
Bassgod
Thanks for giving me a good starting point guys. I will dig into it this weekend hopefully. Do I have to drop my entire dash if it is the blend door, or can the duct work be dropped without that mess?
Old Jan 5, 2007 | 04:58 PM
steve(ill)'s Avatar
steve(ill)
the normal procedure is to take out the dash. Some of the Explorer guys have found a way to remove the glove box door and cut a hole into the duct with a skill saw and pull the door out. I have not heard of a short cut for the F150.
Old Jan 5, 2007 | 05:10 PM
Bassgod's Avatar
Bassgod
Unhappy
Oooh Maaannn!
Old Jan 5, 2007 | 06:32 PM
TJM70's Avatar
TJM70
also could be the motor/actuator that operates the blender door, that's what mine wasa and i had same symptoms. I would make sure to check the **** first hopefully that's what it is and you won't have any problems.
good luck,
TJ
Old Jan 5, 2007 | 07:36 PM
Volfandt's Avatar
Volfandt
Sounds like the temp control **** is broken where it slides onto the rheostat shaft. I had a similar problem.
Just pop the **** off and swap it with the fan control ****. If this fixes it then you're good to go. If not, then you can go deeper.
Good luck
Old Jan 5, 2007 | 07:53 PM
smits03's Avatar
smits03
I would recommend checking out the **** first, i had the same problem with mine in the middle of winter, except it was just blowing cold air. That was a long cold drive to work.
97ExpGuy
Jun 24, 2014 07:01 PM
ballow97
Feb 17, 2014 01:31 PM
sdcharger
Jan 19, 2014 04:14 PM
F100DREAM
Dec 29, 2013 08:07 PM
turnkyle
Oct 1, 2013 12:53 AM
