Temperature control knob adjustments?
Old Sep 29, 2013 | 10:18 AM
turnkyle's Avatar
turnkyle
Temperature control **** adjustments?
Back when I lived in an area that actually got cold in the winter I was having issues with my heater blowing out hot air. Now that I am getting ready to move to another winter state I wanted to fix the problem. I replaced the thermostat, flushed the heater core and checked the blend door for blockages. While checking the blend door I noticed that when the temperature **** is turned all the way to hot the blend door is not fully closed and when it is turned to cold the door is fully open before the **** gets all the way to the bottom of the cold/blue dial. so my question is: Can the temperature **** on a star gear that you can just pull it off and put it back on in the correct orientation or is there an adjustment in the cable somewhere? This is on a 1994 4x4 excab with the 5.8.
Thanks
Old Sep 29, 2013 | 07:19 PM
turnkyle's Avatar
turnkyle
Nobody?
Bump
Old Sep 30, 2013 | 03:41 PM
warren561's Avatar
warren561
I'm looking in the Ford Factory Service Manual PDF that I've got.
It doesn't say that the cable is adjustable... here's the blurb from the service manual:
The A/C temperature cable (19988) requires no adjustment providing all components of the heating
system are in the full warm position prior to installation.
And, in giant bold text there's:
NOTE: All temperature control components are shipped from the factory in a full warm position and must remain in this position until fully installed. In addition, all existing components must be set in a full warm position before any installation can be attempted.
Perhaps a previous owner removed/fixed/re-installed things without setting things all to full warm?
Full Removal Instructions:
1. Disconnect battery ground cable.
2. Release glove box to gain access to the A/C temperature cable (19988) at the heater air plenum chamber (18471).
3. Release the retaining tab on the A/C temperature cable and lift the cable off the heater air plenum chamber.
4. Remove the trim strip above the A/C control (19980) and glove compartment area.
5. Remove two screws retaining the center finish trim panel to the instrument panel (04320).
6. Remove the center finish trim panel.
7. Remove four screws retaining the A/C control to the instrument panel.
8. Pull the A/C control from the instrument panel far enough to gain access to the back of the A/C control.
9. Remove the hardshell electrical connectors from the heater blower motor switch (18578) and the function control switch.
10. Pull temperature control **** (18519) off A/C control.
11. Remove one screw retaining the A/C temperature control bracket (19D816) to the A/C control.
12. Rotate the A/C temperature control bracket and remove from A/C control.
13. Insert Temperature Control Cable Removal Tool T94P-18532-A on A/C temperature cable to release two of three locking tabs. Use a small flat-bladed screwdriver to release the third locking tab and remove A/C temperature cable from A/C temperature control bracket by pulling directly from A/C temperature control bracket.
14. Remove A/C temperature control bracket from vehicle, paying particular attention to routing of cable to aid in installation.
Full re-install instructions:
1. NOTE: All temperature control components are shipped from the factory in a full warm position and must remain in this position until fully installed. In addition, all existing components must be set in a full warm position before any installation can be attempted.
Route A/C temperature cable in the same manner as cable removed.
2. Install A/C temperature cable on heater air plenum chamber by aligning locating tab on the A/C temperature cable with locating position on heater air plenum chamber. Make sure the temperature blend door actuator post is aligned within the cable head cam.
3. Push A/C temperature cable over temperature control door cam until an audible click is heard indicating engagement. If a click is not heard, it will be necessary to visually ensure cable is fully seated in position.
4. Position temperature control in full warm position. Install A/C temperature cable on A/C temperature control bracket and push until an audible click is heard.
5. Install A/C temperature control bracket on A/C control and rotate into position.
6. Install screw retaining A/C temperature control bracket to A/C control.
7. Connect electrical hardshell connectors to heater blower motor switch and function control switch.
8. Install A/C control into instrument panel opening.
9. Install four screws retaining A/C control to instrument panel.
10. Install center finish trim panel around A/C control.
11. Install two screws retaining center finish trim panel to instrument panel.
12. Install trim strip above A/C control and glove compartment area (push on).
13. Install temperature control ****.
14. Rotate temperature control **** and check for proper operation of temperature control components.
15. Attach glove compartment.
16. NOTE: When the battery (10655) has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) relearns its adaptive strategy. The vehicle may have to be driven 16 km (10 miles) ormore to relearn the strategy.
Connect the battery ground cable.
Old Oct 1, 2013 | 12:53 AM
turnkyle's Avatar
turnkyle
Cool, thanks. I will have to dig into the truck some more and see detaching the cable and reinstalling with everything set on full hot will fix my problem.
Sabrejet
Jan 23, 2013 06:41 AM
ford 6.9
Dec 19, 2010 09:48 AM
albertinhouston
Aug 23, 2006 04:57 AM
ntbinkle
Jan 12, 2005 07:21 PM
borin&strokin
Dec 11, 2003 03:07 PM
