Engine makes whining noise
Old Feb 26, 2007 | 10:20 AM
EpicCowlick's Avatar
EpicCowlick
I have the whistle also. Mine sounds like it's coming from the PCV valvle area. I replaced the valve but no change. Were you able to locate the problem and resolve?
Old Feb 26, 2007 | 10:32 AM
Trucker22's Avatar
Trucker22
whistle
Yes I resolved it---I should have posted the answer at this thread but I started a new thread---my mistake
You'll find my solution here:
https://www.ford-trucks.com/forums/5...ter-issue.html
It was a air filter---Fram---didn't fit properly---I still am using it but found a way to center it in the housing better---I'm hoping when it comes time to replace it that I'll find a motorcraft that fits better.
Pull your air filter and look at the sealing surface---should be indents in the rubber---if it isn't uniform all the way around you have the same problem I had.
Old Feb 26, 2007 | 11:09 AM
EpicCowlick
Thanks, I'll take a look at this tonight and let you know. I've also read about a procedure which replaces a hard plastic factory hose with a flexible hose. I'll check both options out.
chris2810
May 18, 2015 03:10 AM
mode101
Jul 22, 2014 12:00 PM
Michael F100 57ig
Jan 23, 2014 08:42 PM
Lincolnman73
New Member Introductions
Dec 9, 2013 04:21 PM
F350XLT
Nov 18, 2013 08:58 PM
