F350 XLT problem after start
Old Nov 15, 2013 | 09:32 AM
F350XLT's Avatar
F350XLT
Hey Guys,
i have a crazy noise after every cold start for a few seconds and when i drive my Truck and hold the rpm the noise come again and my Truck lost the boost.
I think its the VCV or a problem in the DPF system.
Here is a short Audio from the noise.It comes after 11 Seconds.
Truck Information:
1995 F-350 XLT 7.3L Turbo with straight pipe
I hope anybody can help me.
Greetings from Germany
Old Nov 15, 2013 | 10:20 AM
Frozen_Joker's Avatar
Frozen_Joker
That is an icky sounding noise sir!
Almost sounds like some sort of Air/Vac leak.
Old Nov 15, 2013 | 11:40 AM
F350XLT's Avatar
F350XLT
Hey thanks for your support!
I check the air and Vac system next morning.
This is what i think too but the only problem at this failure is i have the noise only on a cold motor.
Old Nov 15, 2013 | 12:02 PM
Frozen_Joker
So if you warmed the motor up and then started it, it would not make this noise?
Old Nov 15, 2013 | 02:24 PM
F350XLT's Avatar
F350XLT
The Motor is warmed up not so long only for 2 or 3 seconds.
Old Nov 15, 2013 | 05:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
i believe that is the exhaust back pressure valve closing to aid in engine warmup.
this is a question best asked in the 94-97 powerstroke forum, down in the diesel section.
the guys down there will help you get everything running tip top shape.
Old Nov 18, 2013 | 10:03 AM
F350XLT's Avatar
F350XLT
Ok the problem is the sensor for the EBPV.
I`ve unplugged the connector and my Truck runs normal.
Need my Truck this Sensor absolutely?Not really!?
Thanks for your great support Guys!
Old Nov 18, 2013 | 10:43 AM
subford's Avatar
subford
I do not have a EBPV on my 1995 5.0L and does about the same thing. One of these days I might try to find out what the noise is.
Old Nov 18, 2013 | 05:25 PM
tjc transport
i ain't rite
EBPV is a diesel only thing Bill.
Old Nov 18, 2013 | 08:58 PM
Diesel_Brad's Avatar
Diesel_Brad
Tom is right. It is the EBPV. It aids in engine warm up. I have been disconnection mine since I have been into power strokes(13 years)
Some can be REALLY finicky and come one when they are not needed. Some truck will throw a code if disconnected(use a 10ohm resistor to stop CEL)
I unplug mine and if I ever take the turbo off, I remove the butterfly for better exhaust flow
Igal Igi Strigonov
General Diesel Discussion
Aug 18, 2018 11:21 PM
lindboep
May 29, 2014 11:48 AM
5rhaulr
Jun 12, 2012 09:29 PM
Taylormade2011
6.7L Power Stroke Diesel
Oct 31, 2011 09:50 PM
lseaver92
Jul 24, 2010 08:59 PM
