9 quart Oil Pan
Old Jan 4, 2007 | 10:14 PM
Brad Brown's Avatar
Brad Brown
9 quart Oil Pan
I was wondering if anyone had installed a 370 9 quart oil pan on a 460 f250 4x4 before? My mechanical said it works fine and has built in baffles. Does anyone have any experience with this sucker? I was thinking that if it wasn't two close to the diff or cross member 9 is better than 6??
Old Jan 5, 2007 | 08:16 PM
greenhighboy's Avatar
greenhighboy
I've got one on my pulling truck. It is a 79 F250 frame and has plenty of clearance. I have also used one on a 77 F150 and had good clearance. Be sure and use the oilpump pickup for that pan.
Old Jan 5, 2007 | 10:12 PM
Brad Brown's Avatar
Brad Brown
Greenhighboy, you don't have any pictures kicking around of it do you? I would sure like a look at what I need to find...... If you had one that would be great! I will get on the look for one right away.... Thanks again!
Old Jan 5, 2007 | 10:13 PM
Brad Brown's Avatar
Brad Brown
Question
Have you every heard of anyone buying a new one from Ford? Maybe?
Old Jan 6, 2007 | 07:38 PM
greenhighboy
Here is a link to Price Motorsport. They sell them new for $96. There is also a picture showing what they look like from the side. I have bought some stuff from them and they were really nice people.
http://www.pricemotorsport.com/html/...ellaneous.html
Old Jan 6, 2007 | 11:47 PM
Brad Brown's Avatar
Brad Brown
Excellent work Greenhighboy! can you tell me if the deeper part is at the back? I will call them monday to order up asap. great job thanks for the help!
Old Jan 7, 2007 | 10:46 AM
greenhighboy
Yes the sump(deep part) is in the rear.
Old Jan 7, 2007 | 11:18 PM
Brad Brown's Avatar
Brad Brown
Thanks again for all the help. this pan should be great for the 4x4! I will show it installed once I get it.
Old Jan 8, 2007 | 12:57 AM
grizz3000's Avatar
grizz3000
Hmmmm, I bought a new oilpan online (sorry, I got in trouble the last time I mentioned the company that sent me a wrong part) and it was too deep to fit in my 89 F250 460. It seemed too deep in front preventing it to go in at the same engine hieght that the old pan came out at. The old pan slide right back in.
Is there markings on the pan somewhere stating the 'size'? A code maybe?
Old Jan 8, 2007 | 08:32 PM
greenhighboy
The front is 7-1/2" deep and the rear is 9-3/4" deep. The distance from the front of the pan to where it changes depth isabout 10-1/2".
Old Jan 10, 2007 | 11:12 PM
Brad Brown's Avatar
Brad Brown
Excellent help Greenhighboy! I was going to have to go out to my buddys shop and measure up the one on his old 3 ton ford bobcat truck! Now I just need to go under my truck and measure up the distances off the existing pan which is a 390 pan.
I am hoping that the 460 block is not as deep as the 390, being a Y block and all. Hopefully the 460 sits up a bit taller in the truck than the 390 to help get more clearance. Anyone have any ideas on this??.
Old Jan 11, 2007 | 07:28 PM
greenhighboy
I really don't think you'll have any claerance problems. The one that I put on the F150 really surprised me that it fit. We used the 360 towers and some solid mounts that are alot like L&L's. The truck also has about 400-500 pounds added to the front for truck pulling. Those coil springs were sure mashed together! The drivers side tire is up inside the fenderwell.
Old Jan 11, 2007 | 10:46 PM
grizz3000's Avatar
grizz3000
I could barely get the stock pan out of my 460. I rose the engine to its limits (started to jack the whole truck up with the engine!).
The larger pan they accidently sent had no chance of fitting.
Best of luck.
JCCFD
Nov 12, 2012 01:51 PM
TheTowingCowboy
Nov 12, 2010 07:07 PM
410 Highboy
Apr 29, 2009 01:38 PM
Ranger1F150
Jul 30, 2007 10:42 AM
