Oil pan
Old Nov 10, 2010 | 06:00 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Oil pan
this claimer oil pan
Small Block Ford Claimer 9 Quart Oil Pans
will it and the 351 fit in the engine bay of my 78 F100 with no problems?
Or if someone knows of any good big oil pans for 351W's that will fit in there with NO MODIFICATIONS I would like to know, I want to have alot of oil (Plus a oil cooler).
Thanks guys.
Old Nov 10, 2010 | 06:05 PM
650's Avatar
650
Does it say if it uses the stock dipstick? I know on mine we had to make our own out of brakeline and a really long dipstick we found at the junkyard.
Old Nov 10, 2010 | 06:16 PM
TheTowingCowboy
Thats a good question. I am just wanting a deeper then stock oil pan. The F100 is going to be a street truck.
Old Nov 10, 2010 | 06:43 PM
BDawg171's Avatar
BDawg171
Not sure about this one specifically, but I wouldnt think you would want a oval track oil pan. The extra capacity & pick up is on one side (left) as if you were pulling hard through corners and oil is slung over to that side. I would keep looking.
Old Nov 10, 2010 | 07:46 PM
TheTowingCowboy
I see, well I am open to suggestions. Thanks Bdawg
Old Nov 10, 2010 | 09:17 PM
crazyeddie's Avatar
crazyeddie
I browsed through the Jeg's catalog and no 351 pans for pickups - quite a few for Fox-Bodies though. Somebody has to make a fabricated sheetmetal pan for 351 truck applications!
Old Nov 11, 2010 | 05:44 AM
BDawg171's Avatar
BDawg171
I'll have to check again, but I thought Moroso made a deep oilpan pans for the 351w. I don't think it said for 4x4 but if your truck is like mine, it looks like there is plenty of room around the oil pan. I have a 351m and Im eventually looking for one as well. If someone else knows the answer, post on up!
http://www.carshopinc.com/product_in...id/65855/20523
Old Nov 11, 2010 | 01:13 PM
ledhead617's Avatar
ledhead617
i got a pretty big pan in my truck...look up a early 80s crown vic with a 351 (cop car) thats what it was out of..not shure if its stock or not but it holds 7 quarts
Old Nov 11, 2010 | 04:50 PM
TheTowingCowboy
7 quart is stock.
Old Nov 11, 2010 | 08:25 PM
TheTowingCowboy
Also would the pan need to be for a pickup? The 302 that came out of the truck had a rear sump pan like a car.
Old Nov 12, 2010 | 04:47 AM
lostinfords's Avatar
lostinfords
pick up?? 2wd or 4wd, front sump for the 2wd rear sump for the 4wd...your 351 is a windsor, most came w/ the modified
Old Nov 12, 2010 | 06:11 PM
TheTowingCowboy
2WD and its a swap in from a 1974 Gran Torino I have. I also want more oil.
Old Nov 12, 2010 | 07:07 PM
maskedman's Avatar
maskedman
GO to the Summit website,they have about 5 pages of 351w oil pan configurations.If you cannot find something there,contact some of the manufacture companies directly.
pauleouellette
Sep 13, 2015 10:46 PM
Fatfenderford
Apr 1, 2015 09:04 PM
caleballen95
May 21, 2014 05:47 PM
ajf99ford
Dec 30, 2007 10:19 AM
robknow
Mar 23, 2004 12:29 PM
