8 quart oil pan capacity
Old 04-27-2009, 06:45 PM
410 Highboy's Avatar
410 Highboy
410 Highboy is offline
I have a 75 F-250 4x4 with the original 360 block ,with a Milodon rear sump 8 quart oil pan . I am assuming the original pan was 5 quart .So add one quart for filter change .I use an extra capacity Wix 51773 .I am coming up with 9 1/2 quarts . I read in HotRod or Carcraft mag about determining level by adding oil until pressure drops . Thanks
Old 04-27-2009, 11:27 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
The rear sump, 4x4 pan holds 6 quarts.
I never heard of this one. Care to share with the rest of the class?
Old 04-28-2009, 09:14 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Yeah, that's when the oil foams up, the pump sucks air in, and you ruin your bearings. But at least you know how much oil it'll take
Old 04-28-2009, 08:53 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Does the pan have a provision for a dipstick, and does it use the stock one? If so, just fill it to full on the dipstick............
Old 04-29-2009, 01:38 PM
410 Highboy
It has a Milodon dipstick . I am looking for the article by Carcraft . I just read it about a month ago . Oil pressure has been fine since I installed the engine ,1500 miles ago .I am getting ready to do my forth oilchange. I look for sales on oil !
coxthecrazy
25
12-20-2013 03:36 PM
madpogue
12-08-2012 09:03 PM
msutton331
05-04-2003 01:53 PM
Matt_W
3.8 & 4.2L V6
12-18-2002 12:36 AM
Quick Reply: 8 quart oil pan capacity
