Clutch Chatter
Old Dec 12, 1999 | 09:36 AM
Steve's Avatar
Steve
Clutch Chatter
My '56 long bed has an unusual clutch problem. When cold, the clutch engages smoothly, forward or reverse, at any rpm. When hot, engagement is fine in forward gear, put in reverse- yeow! really bad chatter. This only happens warmed up in reverse. Truck has a 292, stock 3 speed (in great shape) and stock axle. Motor mounts, u-joints etc are fine. Could excess backlash in the ring & pinion do this? Or what?
Old Apr 5, 2001 | 12:40 PM
Kenny's Avatar
Kenny
Clutch Chatter
Old Apr 7, 2001 | 07:39 PM
whomrig's Avatar
whomrig
Clutch Chatter
Hi Steve, I would take a close look at your reverse gear idler shaft for excessive thrust clearance. Also, as your trans oil warms up, it will thin out some. That can make a difference also. So check it out and let me know.
Wayne
Old Apr 10, 2001 | 06:29 PM
cot's Avatar
cot
Clutch Chatter
>this? Or what?
Old Apr 10, 2001 | 06:35 PM
cot's Avatar
cot
Clutch Chatter
steve, i had the same problem on my 66 gto. rear main was leaking & residue was on the flywheel. it only chattered when it was warm. the flywheel needed to be resurfaced & a new disc solved the problem!good luck chuck
sailor02
1997 - 2003 F150
Jul 6, 2015 06:40 PM
Tectron1
Apr 10, 2015 10:54 AM
Mike1
Mar 22, 2014 06:27 AM
jeffsang
Nov 5, 2013 09:57 AM
jas88
18
Oct 4, 2008 04:50 PM
