c1Ae-6090 ? heads
Old Dec 30, 2006 | 12:03 AM
keisha9's Avatar
keisha9
c1Ae-6090 ? heads
how are these heads and what are they off of? if anyone knows thanks
Old Dec 30, 2006 | 04:45 AM
66 POJ's Avatar
66 POJ
I looked these up in my cylinder head ID book and I came up a C1AE-A head # as a 352/390 head from 1961-63. 71-74cc, 2.02" intake and 1.55" exhaust. Hopefully this is what you are looking for, someone will chime in if not correct.
Old Dec 30, 2006 | 05:16 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Sounds right to me? Yes those are nice heads to put in CJ size valves, and they also have the Tall port which means thay flow real well..and even better with the casting flash and the bumps cleaned up in them..
If I was to run Irons heads again? which I may in the future? I'd run em!!! after they were re-worked.. But out of all the FE heads out there..those are one of the ones in the top of the pecking order!! JMO..
RJ
Old Dec 30, 2006 | 11:50 AM
keisha9's Avatar
keisha9
thats what i wanted to hear! there are so many diff. fe heads i wondered if they werer all pretty much the same or if there was differences that would make a change in a street rod.. u have c4s c8s c7s c1s =
Old Jan 26, 2008 | 12:36 AM
randall2051's Avatar
randall2051
has anyone tried angle milling on fe heads
Old Jan 26, 2008 | 04:37 AM
RapidRuss's Avatar
RapidRuss
Can you explain what you mean by angle milling? I'am an X-Machinist and i'am not firmiliar with that ? Maybe we called it something else 25 years ago ?
RJ
Old Jan 26, 2008 | 05:37 AM
randall2051
removing more deck material of the exhaust side than the intake side reduces the combustion chambers raises the runners and helps deshroud the valves by moving the valves closer to the center of the combustion camber 427head casting c5ae-r
Old Jan 26, 2008 | 05:50 AM
randall2051
ok heads but large chambers 71-74cc
bill11012
Modular V10 (6.8l)
Apr 5, 2022 07:50 PM
stagecall
Jun 5, 2016 01:12 PM
SomeDude451
Jan 29, 2013 10:51 AM
dogstar
21
Nov 11, 2010 12:39 PM
Dirt Head
Aug 27, 2004 07:29 PM
