Steering Wheel Replacement
Old Dec 28, 2006 | 12:54 AM
RMS94's Avatar
RMS94
Will a steering wheel from a 2002 Expedition or or the new F150's fit a 1994 F150? My steering wheel, leather covered, has leather that is in poor condition I would like to replace it. I know about the wheelskins, but I don't want to go that way now. Notice alot of Expedition and new F150 steering wheels on ebay and just wondering if I could use one of them?
Roger
Old Dec 28, 2006 | 01:10 AM
77 Bronco's Avatar
77 Bronco
RMS94, Well, there are 3 problems that I could see you having a problem with. 1st being the wheel itself being able to have the proper spline to slide onto the steering column shaft and be properly seated. 2nd is the "Air Bag Sliding Contact" otherwise known as the clock spring needs to be able to plug in to the existing steering column harness. 3rd but not least is the "Air Bag Module" and it needs to be compable also. So basically as long as the spline is the same as well as all the plugins being compatable and the steering wheel itself will fully seat down on the steering column shaft, then I seen no problem. Good Luck.
Sam
Old Dec 28, 2006 | 06:36 PM
lostin90s's Avatar
lostin90s
Get a quality leather stich on wheel cover $20.00. Did last truck couldn't tell from new when done . Do Ebay search for both bronco and Fseiries and check ebay stores on bottom ebay page . I saw new wheel just last week for are trucks was at $50 bucks.
Goodluck
_______________________________________
94 F150 XLT 4x4 sc lb maf 302 E4od 3.55 rears
Old Dec 28, 2006 | 09:17 PM
RMS94's Avatar
RMS94
I was following the one last week. I lost interest at $125. Let me know if y'all see another one.
Roger
Old Dec 28, 2006 | 10:44 PM
jk89cat's Avatar
jk89cat
arnt they stil available from ford? i can check tommarow
Old Dec 30, 2006 | 11:15 AM
jk89cat's Avatar
jk89cat
still available ,leather with air bag , f6tz.3600.aab msrp is 188.73
Old Dec 30, 2006 | 01:29 PM
RMS94's Avatar
RMS94
Found it at Directfordparts.com for $132.26. Anyone dealt with this company before?
Roger
FrankeeD
Sep 3, 2022 06:22 PM
Davparks
Oct 21, 2017 08:28 AM
Fordication
Sep 9, 2016 07:20 PM
MR Smitty
Appearance & Dress-Up
Oct 22, 2015 04:45 PM
jimmyburg
Mar 20, 2008 10:14 AM
