Need Help ID'ing Rear Axle
Old Dec 29, 2006 | 11:13 PM
Tom-O's Avatar
Tom-O
I want to buy an aftermarket rear diff cover, but I don't know what type of axle my truck has -- how do I figure it out?
My truck is a 1992 F350 crewcab, dually, 7.5L(460cid), E4OD, rear-wheel-drive (not 4x4).
I'm guessing the VIN might tell me, but I need some sort of cross reference or some sort of deciphering manual to tell what the numbers in the VIN code mean, don't I?
From looking at pictures, and other info, I'm guessing it might be a Dana 60 or a Ford 10.25. I might be way off. I don't know anything about these axles.
Anyhow, thanks in advance for the help.
Old Dec 29, 2006 | 11:20 PM
lorenr's Avatar
lorenr
Wink F 350 Rear
I believe it is a Sterling 10.25 ring gear,
I don't think they went to the 10.50 ring gear until after 1992. But no matter I'm sure they both take the same cover.
Old Dec 30, 2006 | 12:49 PM
Tom-O's Avatar
Tom-O
LorenR -- Thanks for the reply. I guess my guesses were closer than I thought. Is there a way to be totally certain of the axle type? Or ar you totally certain? I just don't want to order the part, then find out after I've removed the cover and drained the diff that it's the wrong part -- then have to ship the part back and wait for a new one (you probably get the idea).
Anyhow, thanks again.
Old Dec 30, 2006 | 01:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
a sterling 10.25 rear has 12 bolts holding the cover on.
the dana has 10 bolts holding the cover on.
Old Dec 30, 2006 | 01:15 PM
Tom-O's Avatar
Tom-O
Tom --
Thanks. I counted the bolts on the diff cover -- there are 12. So, apparently my axle is a Sterling 10.25.
I also looked at the door sticker and the axle code is: "D5" I don't know if this has anything to do with the type of axle or just the ratio. I'm assuming the ratio is 4.10. There is a small metal tag on one of the diff cover bolts and I'm assuming this is just some sort of serial number.
Also, what does "sterling" mean? Is this a manufacturer, or what? I've heard the term used with "Ford" as in, "Ford Sterling." Is Sterling a division of Ford? Just curious. Thanks again.
Old Dec 30, 2006 | 01:42 PM
tjc transport
i ain't rite
that little tin tag is you axle info. if the tag says 4L10, you will have a 4:10 limited slip diff.
fastmover
Exhaust Systems
13
Feb 13, 2007 07:42 PM
7.3Diesel
17
Jan 4, 2007 04:03 PM
wifes65
Electrical Systems/Wiring
Jan 2, 2007 06:48 PM
fordster40
Dec 21, 2006 09:33 PM
daverennie
Nov 8, 2006 09:17 AM
