Does anyone know where I can find a tail section for a BW 1356 transfer case that has the speedometer adapter in it. I am putting a 9inch rear end in and this will cause me to lose my speedometer. Has been said that there is a tail shaft for a BW1356 that has the speedometer adapter in it. Currently my truck has the speed sensor for the rear end. 9 inch does not support this. Any help?
I know the '87-'89 have them in the tail shaft, but I think there is more to just swapping the tailshaft. Junkyards have them all day long, probably can get one at a u-pull it pretty cheap.
Thanks, for the information. I will need it inorder to run an analog speedometer. All the wiring in the truck is going away, and is going to be replaced.
i'm doing the opposite in my truck, i've got a 1356 from an 89 and need to block the hole off for the speed sensor. anyone know if there is a part made for this or do i need to find a newer tailshaft in junkyard also??
Maybe we can work out a deal to just swap tail shafts. Am willing to ship mine first if you would like. My truck is currently down for the rearend upgrade.
