Offroad & 4x4
BW 1356 ?
Old Oct 13, 2010 | 08:26 PM
mxzx's Avatar
mxzx
BW 1356 ?
Say I had to remove my rear driveshaft on slip yoke BW 1356 transfer case because of trail damage. Would I be able to limp it home in front wheel drive or would I lose all the fluid. Could it be capped off?
Old Oct 13, 2010 | 09:16 PM
79Ford4x4's Avatar
79Ford4x4
you gonna loose fluid there. Try and use some duct tape or simular to cover the opening. Last time i dropped a rear shaft i just grabbed the parts, threw it in 4, and hauled tail back to the house. About a 45 min drive and when i got home the case was dry and hot. Added some fresh fluid and worked fine.
Old Oct 13, 2010 | 09:19 PM
captain p4's Avatar
captain p4
If the shaft is bad enough, cut it off and shove the slip yoke back in, then find a creative way that I can't think of right now to hold it in there
Old Oct 13, 2010 | 10:10 PM
Prozon's Avatar
Prozon
I think duct tape and rags to try to cap it would be best..
Old Oct 13, 2010 | 11:45 PM
fatdan460's Avatar
fatdan460
i used to think about this a lot. my 85 had a 208 with a slip yoke rear. as far as i know the ford 208's were fixed yokes, but i didn't build it, so idk.
i left a roll of bailing wire in the tool box just in case assuming i could figure some way to wrap up the d-shaft and keep it in for a ride back home. don't know if it would have worked, but i assume it would for a short trip.
Old Oct 14, 2010 | 12:03 AM
Prozon's Avatar
Prozon
When I busted the rear driveshaft and such, I just pulled it out and put it in 4x4. I don't think it leaked at all.
Same T-Case as the OP.
Fluid was full too lol.
Old Oct 14, 2010 | 02:27 AM
hav24wheel's Avatar
hav24wheel
I'd think a pop can or bottle taped over the output would work best. That way you can keep a gap between the output shaft and the thing u cover the hole with. Don't want the shaft to rub on anything.
Old Oct 14, 2010 | 05:55 AM
kjett's Avatar
kjett
an empty quart gear oil bottle works great to cover the opening with the help of a little duct tape
Old Oct 14, 2010 | 10:07 PM
mxzx's Avatar
mxzx
Thanks for the ideas!
Ian_C
Mar 9, 2015 09:22 PM
tilopa
Dec 3, 2013 01:44 PM
AndysFords
Offroad & 4x4
Sep 11, 2011 06:31 PM
brodas3
Aug 19, 2007 05:08 PM
leadmic
Apr 27, 2004 04:58 PM
