General Automotive Discussion
1996 ford escort ignition/powertrain control module????
Old Dec 21, 2006 | 01:51 PM
websthes's Avatar
websthes
chilton says the ICM is by the fuse box. i have two 96 escorts and i see nothing
my haynes manual says the 96 1.9L escort ICM is built into the powertrain control module (PCM) and it's a dealer service item
i just want to know where the powertrain/ignition module is. i won't try and test it if i don't have accurate instructions. but if i can take the one off the other car and keep it with me as a spare i will
Old Dec 21, 2006 | 02:14 PM
Racerguy's Avatar
Racerguy
On a 1.9L Escort the ICM should be on the front of the driver's side strut tower. It should have 2 nuts holding it on and 1 electrical connector.
What sort of problem are you having with the car?
Old Dec 21, 2006 | 03:52 PM
websthes's Avatar
websthes
its not there.. i have two '96 escorts and neither one
there's no problem i just wnated to know where it is so whatever it is i'm gonna take it off escort #2 and keep it in escort #1 just in case.
Old Dec 21, 2006 | 08:29 PM
Racerguy's Avatar
Racerguy
The shop manual shows that the 1997 Escort has the ICM built into the PCM. Could your cars be late build 96s maybe?
Old Dec 21, 2006 | 10:41 PM
websthes's Avatar
websthes
the haynes book i have says that the 96 has the ICM built into the PCM.
i thought it was odd but i have two 96 escorts, one for driving and one for parts, and neither one has an ICM that i can find.
where is the PCM on the 97? what is it attached to?
Old Dec 21, 2006 | 10:46 PM
Racerguy's Avatar
Racerguy
The info I posted is from the Ford shop manual. Strange that it's wrong but anything is possible.
The PCM is under the center of the dash, under the console.
Old Dec 21, 2006 | 11:03 PM
websthes's Avatar
websthes
the bracket to hold the ICM is there... on both '96 escorts... but no ICM
i'm gonna have a look for the PCM tomorrow.
is the PCM something i can just unplug and plug in again or will that damage it? why is it a dealer service item?
if something happens to the car and i have no ignition and i think it's the ICM, can i just put in the other one and make my car work again or does it have to be programmed or something???
Old Dec 21, 2006 | 11:16 PM
Racerguy's Avatar
Racerguy
If the donor PCM is exactly the same.....both the same engine, transmission etc, it should plug in and work.
They really very rarely die though. If you had no spark it would more likely be a coil or crank position sensor or something like that.
Motorhead-42
80
Jul 27, 2016 02:30 PM
ifiteverruns
22
Mar 30, 2015 11:54 AM
khruldavid
1983 - 2012 Ranger & B-Series
Nov 26, 2014 07:54 AM
njxlt
Jan 2, 2004 09:56 PM
propellerhead
Computer Chips & Tuners
May 12, 2003 07:39 PM
