Installing a 7 pin plug
Old Dec 21, 2006 | 06:59 AM
campin' nut's Avatar
campin' nut
I have a '99 f250 superduty and want to install a 7 pin plug. The only thing there now is the 4 wire flat plug wiring harness coming out of the plug under the truck. It has the factory tow package on it so will it already have the wiring run to the back of the truck for the 7pin plug? If so then all I should have to buy is a new wiring harness from ford, correct? I just don't want to have to splice into the factory wires in the back if I don't have to.
Old Dec 21, 2006 | 09:28 AM
HomerWinzlow's Avatar
HomerWinzlow
You should be able to get the complete pigtail assy from Ford for about 100 bucks. You may also need some relays in the little relay boxes under the hood.
Old Dec 21, 2006 | 11:13 AM
campin' nut
Thanks for the reply. I will try to get the assembly today. I suppose they will tell me what relays I need?
Old Dec 21, 2006 | 11:21 AM
HomerWinzlow
Well most vehicles that were equipped with trailer tow package came with the relays and a trailer controller wiring harness, 7 pin connector already installed with hitch assembly. I think you will need one or maybe two of the full sized Bosch type common accessory Ford relay. Look in your owners manual for placement.
Old Dec 23, 2006 | 06:03 AM
bobbynj66's Avatar
bobbynj66
When I did it to my truck I went to walmart they sell the inline plug for the 7 wire with everthing there just unplug and put the new one in it is a T connection goes inline.Check it out might save you some $ all the relays were in mine already
wasmblad
All Things Towing
Jul 22, 2013 10:05 PM
pzp107
All Things Towing
May 17, 2013 08:12 PM
dlturner00
Aug 21, 2009 07:23 AM
Toisich
All Things Towing
15
Dec 13, 2005 11:20 AM
richard01
All Things Towing
Sep 12, 2005 05:15 AM
