Round Camper Plug Wiring
Old Sep 9, 2005 | 12:37 PM
richard01's Avatar
richard01
Question Round Camper Plug Wiring
I have a 95 F150 and would like to wire up electric brakes. My truck is pre-wired for the brake controller. There is also a two factory plugs in the wiring harness in the back. Where can I get a 7pin round recptacle for the bumper that wires all seven connections to the two factory plugs in the back? You must be able to get one somewhere or why would Ford supply the factory plugs in the factory wiring harness. Can anyone point me in the right direction? I have an after market 7 pin round receptacle but have no way plugging it into the factory harness without cutting the plugs off. That just doesn't make sense to me to have to do. Thanks for all replys.
Old Sep 9, 2005 | 02:43 PM
CmprSpecial's Avatar
CmprSpecial
I think this is what you are looking for http://www.draw-tite.com/products/pr..._harness.shtml part number 20030 Draw-tites OEM replacement harness..
On edit.. Check the bottom of this link, http://www.hitchfinder.com/wiring_ad...6-Way%20Wiring The sell OEM cables too...
Old Sep 9, 2005 | 04:50 PM
kingfish51's Avatar
kingfish51
You can also buy the recepticles with bracket from Ford. I had to replace the one on my 98, Just plug it in and bolt the bracket to the bumper.
Old Sep 12, 2005 | 05:15 AM
richard01's Avatar
richard01
Thanks all. I will give all of the suggestions a try. I do believe that I called Ford earlier and they could not confirm that it would wire into the existing wiring. Thanks again.
dawhits1
29
Jul 7, 2021 08:27 PM
HHCIB
Oct 4, 2015 01:48 PM
Ristin
Jul 19, 2013 11:59 PM
soxfan81
2004 - 2008 F150
May 8, 2008 03:22 PM
Moonblink
All Things Towing
May 14, 2004 06:06 AM
