how to program a ford keyless entry???
Old Mar 8, 2004 | 06:29 AM
nb1997's Avatar
nb1997
I call Ford yesterday and girl there told me to turn my ignition on and off 6 to 8 time then press my lock button on the new keyless entry remote and the infared will program my new remote.
This is not working!! If I keep doing this I'm going to wear out my ignition. Any ideas?
Thanks,
Nate
1999 Ford F250 PSD CC 4x4
Old Mar 8, 2004 | 09:33 PM
prcrboy's Avatar
prcrboy
What part of the keyless entry are you trying to program?
If its the keyfob she is right. But you have to do this without starting the truck. Just turn the key on and off 8 times within 10 seconds and the doors will lock and unlock. YOu then must program all the keyfobs you want to use. Do so by pressing lock button on each one, one at a time. When finished turn off the switch.
Old Aug 9, 2004 | 05:11 PM
russell_t's Avatar
russell_t
I could use some assistance with this process also.....
In addition to what was mentioned above. (and having tried it MANY times)My dealer said that there was a connector in/behind the glove compartment that when bridged and the key then turned on would allow the new keyfob(s) to be programmed. I can't find any thats not connected & has 2 wires. (I have found 2 connectors, one w/ 1 wire & 1 with 4 (if I remember correctly) wires
I am having to replace 2 damaged keyfobs & would appreciate any help.
thanks in advance....
Old Aug 9, 2004 | 06:51 PM
HomerWinzlow's Avatar
HomerWinzlow
It varies by vehicle, model and year. Some cycle only 5 times to go into program mode. Some vehicles DONT HAVE factory keyless. Are you sure you arent trying to program key fobs to a vehicle without keyless?
Russell, the much older model vehicles had the jumper... what year and model do you have?
Old Aug 10, 2004 | 07:08 AM
russell_t's Avatar
russell_t
I have a '94 Eddie Bauer Bronco, w/ most of the options (no cd player) but I have pwr windows, locks & the old damaged keyfobs were typical ford.
I have tried the key technique atleast a dozen times last night w/ no responce from the truck and looked for the connector w/ no luck.
Any ideas?
Old Aug 10, 2004 | 12:16 PM
HomerWinzlow
Russell this is the exact wording from the service manual for Bronco..
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
Key off. All doors should lock then unlock.
Check operation.
Old Aug 10, 2004 | 12:52 PM
russell_t's Avatar
russell_t
Thanks....I'll try to find this connector this evening.
Can you tell me where the emote entry receiver module is located? Is it behind the glove box?
Old Aug 10, 2004 | 05:47 PM
HomerWinzlow
The remote entry receiver module is located in the LH side of the lower instrument panel to the right of the steering column, just above the driver's right foot area.
It should have a premium sound amplifier for the stereo on the same bracket.
Old Aug 11, 2004 | 07:36 AM
russell_t's Avatar
russell_t
Thanks for the info 'Homer'.... I found the conector & have keyless entry again!
WHHOOOO HOOOOO!!!
Thank you for helping me.
Old Dec 23, 2006 | 09:59 AM
uss_reynoc's Avatar
uss_reynoc
Hi - I have a 94 F150, and saw a post that may lead to some help for me....I have tried jumping the pins in the programming connector without any success. I sit in the truck, fasten my seatbelt, unlock the doors, turn key to ACC (or to RUN), then jump the pins. The doors do not lock/unlock to confirm programming mode. Any idea if I run a voltmeter across those pins what I'll find? My one remote works fine...just trying to add additional remotes. Appreciate any thoughts.....thanks! Charlie
Old Dec 23, 2006 | 10:33 AM
HomerWinzlow
Reynoc, welcome to FTE and you have a PM in regards to this problem.
Seahn
Feb 7, 2025 03:05 PM
eman588G
Sep 25, 2016 09:18 PM
twigsV10
13
Sep 28, 2015 10:33 AM
lalevant
Oct 8, 2008 05:47 PM
waldreps
Dec 23, 2006 09:50 AM
