Sponsored by: Auxito
Keyless Entry
Old Dec 20, 2006 | 03:46 PM
DMurray06's Avatar
DMurray06
Keyless Entry
Hey: I just bought a used F-150 with keyless entry i am assumeing they had there own code when they had it. Just wondering how i could reset it and program my own in?
Old Dec 20, 2006 | 06:56 PM
ncranchero's Avatar
ncranchero
Are you speaking of the door keypad only?
Old Dec 20, 2006 | 07:38 PM
DMurray06's Avatar
DMurray06
yes i am, sorry
Old Dec 20, 2006 | 08:23 PM
wegot3's Avatar
wegot3
The instructions for mine was in the owners manual.
Old Dec 20, 2006 | 08:35 PM
Redbob's Avatar
Redbob
I'm in the same boat; just bought a fine '98 Explorer as a back-and-forth to work car, of a Toyota dealer's lot; my wife loves it, and wants the keyless entry doorpad to work.
The owners manual says the door code is on the owner's card - long-gone of course - and on the "computer."
Which computer would that be? The ECU sticking through the firewall? I pulled the glovebox out, looked at it, but didn't see any sign of any code.
The local $tealer would be glad to decode it for me, of course, but I'd rather decode it myself if possible.
Old Dec 20, 2006 | 11:03 PM
Tinker1000's Avatar
Tinker1000
The computer it's talking about is the Remote Antitheft Personality Module (RAP module) on the firewall on the drivers side. It should be a small beige box right behind the emergency brake peddle with a black plug and some wires stuck into it. You'll need to shove your head under the dash and aim a flashlight straight up behind the brake peddle to find it. There will be a 5 digit number clearly printed on a white sticker on the box. That is the master pin # for the door lock. This code will always work to open the door.
To erase a previous owners code;
1. Enter the master code.
2. Press the 1/2 button within 5 seconds of step 1.
3. Press 7/8 & 9/0 within 5 seconds of step 2.
All personnal codes are now erased and the keypad will only work with the master code.
If you want to replace the previous owners code with your own, see below.
To set your own code;
2. Press 1/2 button within 5 seconds of step 1.
3. Enter your own personnal code.
The door will now open with either code. Entering a new personnal code erases the previous personnal code. The master code can never be erased.
Entering either code will unlock the drivers door. To open all doors, enter the code, then press the 3/4 button within 5 seconds of the drivers door opening.
Hope this helps. If need be, I can post some pics on this when I get home to my other computer in a week or so.
Old Dec 21, 2006 | 03:05 PM
DMurray06's Avatar
DMurray06
cool, thx alot this helps alot!
Old Dec 21, 2006 | 05:15 PM
Redbob's Avatar
Redbob
Thanks.
I found the "computer" over the LH rear wheel well, pried the trim panel away from it with the lug wrench, and read the code fairly easily except for the last digit, which wasn't real clear.
But I got it OK, and now I can leave the key where it belongs - in the truck!
Old Dec 21, 2006 | 08:15 PM
Tinker1000's Avatar
Tinker1000
Cool, glad i could help.
Sorry Redbob, I didn't notice that you have the explorer. I hope you didn't go poking around under the dash for long. I should have warned you that the box is in another position for your truck.
2Wise4aGM
Sep 19, 2010 04:12 PM
fishinford
2004 - 2008 F150
50
Feb 17, 2009 08:32 PM
ssjrsw
Jan 22, 2006 07:09 AM
logginhard
May 15, 2004 11:23 PM
gdogf150
1997 - 2003 F150
May 21, 2003 02:28 PM
