General Diesel Discussion
New Cummins
Old Dec 18, 2006 | 07:03 PM
johndeerefarmer's Avatar
johndeerefarmer
New Cummins
I heard today that the new Cummins will make 650 ftlbs of torque at 1500 rpm...
Sounds alot better than the 2000 of the PSD
Old Dec 18, 2006 | 10:19 PM
duramaximizer's Avatar
duramaximizer
yep that's correct.
Old Dec 18, 2006 | 11:38 PM
Pocket's Avatar
Pocket
On paper is one thing, but we'll have to wait until they hit the streets to see how these engines perform in the real world.
Old Dec 18, 2006 | 11:50 PM
catfish101's Avatar
catfish101
Actually, the old ISB's had an emergency vehicle rating that was well the 600's on torque and 300 HP. I know a guy that put a "Cummins" ecm on his Dodge and changed some parts per CPL. He distroyed the drive train. It was funny.
Old Dec 19, 2006 | 07:45 AM
origcharger's Avatar
origcharger
Cummins website says 610 ft. lbs. @ 1600 rpm for the 6.7 in the 3500 Chassis Cab
Old Dec 19, 2006 | 10:06 PM
duramaximizer
Ya the chassis cabs are rated at the old hp and tq numbers. The new 250 and 3500 will have the new numbers which I am pretty sure will outperform ford and gm. That is good low end grunt that will hold gears when pulling a load if they are even remotely close on the transmission programming.
This is sweet stuff.
Old Dec 19, 2006 | 10:33 PM
ghunt's Avatar
ghunt
I was surprised to read that the new Cummins will be a V8. I figured they were keeping it a 6 and just punching it out to 6.7L.
Old Dec 20, 2006 | 07:17 AM
origcharger
The 6.7 is still a six banger.
Old Dec 20, 2006 | 07:20 AM
origcharger
What, the chassis cabs are derated? Ford guys are blowing a gasket that the F450 Powerstroke is derated as compared to the F250 & F350.
Old Dec 20, 2006 | 09:34 PM
ghunt's Avatar
ghunt
Four Wheeler magazine says it's a V8?
Old Dec 20, 2006 | 10:26 PM
utahtom's Avatar
utahtom
The 6.7 liter Cummins is an in-line 6 cylinder. It certainly will be interesting to see who fairs best when the first year production (PSD & Cummins) hit the market... and we can't ignore the Dmax. IMO fuel quality will really be critical with all the new emission systems/garb in place.
Old Dec 20, 2006 | 11:09 PM
Jerme's Avatar
Jerme
Cummins is developing two new smaller diesel engines, one being a v8, rumored for the dakota and ram 1500.
Old Dec 21, 2006 | 11:20 AM
origcharger
As you can see below, the 650 foot pound version of the 6.7 Cummins will only be available with the 6 speed automatic transmission, the 6 speed manual buyers will have to settle for 610 ft.lbs. of torque;
<TABLE><TBODY><TR><TD class=engine_name>5.7L HEMI® V-8
6-Speed Manual Transmission
</TD><TD class=engine_spec>345 hp
375 lb-ft of torque
375 lb-ft of torque
375 lb-ft of torque
</TD><TD class=engine_spec_na>-</TD><TD class=engine_spec>330 hp
375 lb-ft of torque
</TD><TD class=engine_spec_na>-</TD></TR><TR><TD class=engine_name>5.7L HEMI® V-8
5-Speed Automatic Transmission
375 lb-ft of torque
375 lb-ft of torque
375 lb-ft of torque
375 lb-ft of torque
</TD><TD class=engine_spec_na>-</TD></TR><TR><TD class=engine_name>†5.9L Cummins® Turbo Diesel I-6 6-Speed Manual Transmission</TD><TD class=engine_spec_na>-</TD><TD class=engine_spec>325 hp
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
</TD></TR><TR><TD class=engine_name>†5.9L Cummins® Turbo Diesel I-6 4-Speed Automatic Transmission</TD><TD class=engine_spec_na>-</TD><TD class=engine_spec>325 hp
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
</TD></TR><TR><TD class=engine_name>‡6.7L Cummins® Turbo Diesel I-6 6-Speed Manual Transmission</TD><TD class=engine_spec_na>-</TD><TD class=engine_spec>350 hp
610 lb-ft of torque
</TD><TD class=engine_spec>350hp
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
610 lb-ft of torque
</TD></TR><TR><TD class=engine_name>‡6.7L Cummins® Turbo Diesel I-6 6-Speed Automatic Transmissio
</TD><TD class=engine_spec_na>-</TD><TD class=engine_spec>350hp
650 lb-ft of torque
650 lb-ft of torque
650 lb-ft of torque
650 lb-ft of torque
650 lb-ft of torque
</TD></TR></TBODY></TABLE>
† No longer produced after Dec. 2006 (available while supplies last)
‡ Late availability Jan. 2007 (6.7L replaces 5.9L
Old Dec 21, 2006 | 08:11 PM
duramaximizer
It was the same way when GM offered the manual in their trucks.
It is the same way the 450 is derated as is the gm 4500... dodge does the same thing to the 3500 chassis cab for longer-life.
whitechocolatefrogs
Dec 29, 2011 12:51 PM
Navy_Cowboy_22
Ford vs The Competition
115
Aug 29, 2007 11:49 PM
1BDTrk
43
Oct 22, 2004 11:53 AM
donjo69
80
Oct 12, 2002 07:43 PM
