1978 - 1996 Big Bronco
Bronco wont shut off!
Old Dec 17, 2006 | 07:04 PM
cbgv2000's Avatar
cbgv2000
Howdy all.... I have a 90 and 91 Bronco fullsize with 302 and i can not get the truck to turn off with out pulling the coil wire and damn does that hurt... Is there something i need to look for to replace (already replacesd the key cylynder) Is there a way to bypass all of this? I am about to install a push button starter switch... Thanks
Old Dec 17, 2006 | 07:35 PM
scbronco's Avatar
scbronco
hey
well i have the push button in my truck but your still going to need to turn the key unless you have a mechanical key problem
i mean im sure you cold so a master switch from the battery but i dont know how good thats going to be on all the trucks components cause its gonna cut the power to everything at once
Old Dec 17, 2006 | 07:37 PM
cbgv2000's Avatar
cbgv2000
the truck still wont shut off.... what do i need to get this fixed... is there an easy fix?
Old Dec 17, 2006 | 07:38 PM
scbronco's Avatar
scbronco
well what happens when u turn the key the activation rod that goes down the top of the steering column might not be connected
Old Dec 17, 2006 | 07:44 PM
cbgv2000's Avatar
cbgv2000
how do i get to that and what does it involve to fix it?
Old Dec 17, 2006 | 07:53 PM
scbronco's Avatar
scbronco
well im just saying that as a suggestion im not 100 percent
but you take the 2 sleeves that wrap around the column near off and theres a linkage rod on the top running down the shaft see if it moves when you turn the ignition off
Bronco2015
Apr 1, 2014 03:28 PM
mdr617
Bronco II
20
Mar 17, 2011 11:01 AM
scoug001
Oct 21, 2008 03:54 PM
Paulhala
May 1, 2003 07:34 AM
KcMstang
Aug 31, 2002 12:06 AM
