Sponsored by: Auxito
Sudden shut off?
Old Dec 16, 2006 | 07:23 PM
ChevmaninaFord's Avatar
ChevmaninaFord
Sudden shut off?
I was driving home from school, I pulled into the gas station and right when I began to turn into a parking spot when the power steering went out and the truck shut off. The "Service Engine Soon" light came on for a bit then went off. The truck then started right back up and didnt have any trouble for the rest of the way home. The truck has 154K on it, its a 99 with a 4.6L.
Old Dec 16, 2006 | 07:55 PM
KSopocy's Avatar
KSopocy
Has the alternator ever been changed on your truck? I had the same problem and found that the bearings in the alternator were going bad. This caused the alternator to lock up momentarily, thus stopping the belt, which also drives the power steering pump. Just a thought and it happened to my 99 4.6.
Old Dec 17, 2006 | 03:10 PM
ChevmaninaFord
Is there a good way to tell if the bearings are wearing out?
Old Dec 17, 2006 | 05:14 PM
NewHolland's Avatar
NewHolland
Take the belt off and turn the alternator by hand..If its free wheels and coasts, it should be ok..If it sounds rough when you turn it or turns hard,most likely the bearings are getting bad..At that many miles it could be very possible..
Kamstutz
Jun 26, 2014 12:49 AM
BWMW1971
Dec 3, 2012 06:56 PM
ddunn
Feb 6, 2010 08:03 AM
Busker
1983 - 2012 Ranger & B-Series
Oct 16, 2008 04:19 AM
Ford4x4-JD70AB
Sep 7, 2008 12:44 PM
