EBPV:Exhaust brake Help
Old Dec 17, 2006 | 10:33 AM
Kwikkordead's Avatar
Kwikkordead
Sorry for the crude picture, this is the way that mine is wired now. It's a six pole three position On/Off/On switch that enables me to run with the factory config (EBPV working as designed), or completly disabled in the Off position, or Exhaust brake engaged. I never get a light.
Old Dec 17, 2006 | 10:39 AM
Uzumati's Avatar
Uzumati
You shouldnt get a light with that config kwik but he said he cut the wires to the pcm and taped them off. That is why he is setting the light at key on.
Old Dec 17, 2006 | 10:47 AM
Kwikkordead
Except that when my switch is in the Off position, it's the same as being cut. The circuit is wide open on both wires to the PCM.
That's why I'm thinking it odd.
Old Dec 17, 2006 | 10:51 AM
rebelchevy02's Avatar
rebelchevy02
I know your talking about "Brutusbux" but mine is just unplugged, im not going to use it as a exhaust brake, my luck it would stick, and melt my turbo, so i just unplugged it so i can drive when its cold in the winter
Old Dec 17, 2006 | 10:54 AM
Uzumati's Avatar
Uzumati
That is odd cause if your switch has the solenoid disconnected at Key On when the PCM runs its self test it should set the light. I wonder if Ford changed the self test programming on some of the PCM codes?
Old Dec 17, 2006 | 10:58 AM
rebelchevy02
Im not sure, but im not complaining either, SES, and other lights on the dash bother me. It does seem to cycle the other tests, abs, etc.
Old Dec 17, 2006 | 11:05 AM
clintl's Avatar
clintl
so i am getting ready to clean my epbv tube until i read this post will the same happen to me i mean not being able to start the vehicle if so how can i avoid this if i can?sorry to interfear on this post.oh can you spray something down the tube to help ease the soot to come out thanks
Old Dec 17, 2006 | 11:08 AM
Uzumati's Avatar
Uzumati
Cleaning the tube won't cause any problems (unless it gets broken).
The problem here is the exhaust brake mod at the EBP solenoid. The sensor and tube are on the opposite end of the motor.
Old Dec 17, 2006 | 11:48 AM
rebelchevy02
I cleaned mine out without any problems, although it didnt fix my problem, my problem is that the ebv is sticking... Cleaning out the sensor didnt cause me any problems at all. I used a piece of wire in a drill, because i was unsure how far in the bottom of the sensor was.
Old Dec 17, 2006 | 02:42 PM
brutusbux's Avatar
brutusbux
Well I put it back to factory to make sure I didn't short anything out...and everything is fine...no more code...I was wanting to eliminate the PCM control of the EBPV due to sticking issues...Another concern I have is the hard start issue that arouse after I cut the solenoid wires...I got it started last night and it ran fine and restarted without any problems, now this morning it did not want to start either...I pulled codes (same code) and then cleared and it started right up (this was before I reconnected the factory wires)...after that it has started everytime...does not having the EBPV functional and cold temps make for hard starts (30 overnite)...I did not think this was an issue, just slower warm up time, just trying to understand the hard start
Old Dec 17, 2006 | 05:10 PM
jtharvey's Avatar
jtharvey
This may be. My EBPV wires from the PCM are cut and at a dead end. The only power to the solenoid comes from the switch in the cab. But, that has never caused my SES light to come on. There is a soft code stored, indicating a problem with the EBPV, but no SES light.
Uzumati's Avatar
Uzumati
It shouldn't effect the actuall start the EBPV is not commanded until after starting.
Old Dec 17, 2006 | 07:16 PM
  #28
FARM69's Avatar
FARM69
How does one clean the EBPV? I will be doing this to my rig later this week. I also don't want it to stick if I'm using it for a break.
Old Dec 17, 2006 | 07:52 PM
  #29
Kwikkordead
They are not actually talking about cleaning the EBPV itself, but the sensor that reads how much exhaust back pressure is being generated. It's mounted up front in front of the HPOP, toward the starboard side of the truck. There is a steel tube a little larger than a brake line going from the bottom of that sensor to the exhaust manifold that often gets clogged with soot.
bcg
15
Sep 19, 2015 07:42 PM
DanielT28
Nov 18, 2014 09:48 PM
santacruzf250
Dec 2, 2012 03:03 PM
KonaGrown
17
Apr 27, 2011 10:31 AM
kelwar
Oct 28, 2009 07:49 PM
