EBPV:Exhaust brake Help
I just finished the EBPV for exhaust brake per kwicks instructions and tc lockup per guzzles...when I started for the first time I noticed a service engine soon light...short drive and I have no power with the switch on or off...no turbo...pulled codes and they are p0475 and p1278
I have read on other threads that the p0475 is due to the EBPV being disconnected....what about p1278 (no turbo boost detected)
Oh yeah I cannot get the truck to start now!
2001 7.3 Excursion
2001 7.3 Excursion
Update....I got the truck started....cleared codes (SES light off) rechecked codes only p0475 and everything seems to work fine...test drive went good....came back turned off and restarted the SES light came back on...checked codes the p0475 is the only code no more p1278...is there anything to do to stop the SES light from coming on?
Thanks
Thanks
To get the truck started...well I was agitated so I walked away...came back later and it would crank with no start, then it started...no trouble since then, don't know why or what caused the no start problem
To hook up the new wires I ran a switch with 12v to and sent the load from the switch through a 10 ohm resistor to the connector for the EBPV (gry/rd), I cut the wires from the PCM off the connector and taped them off (rechecked still taped), ran a new ground in the engine compartment and connected to the black wire on the connector
Is there anything I left out...anything else to do to the factory wires from the PCM that would alleviate this
Thanks
Thanks
I have no idea. I do know that you have to be very very careful about not backfeeding voltage to the pcm. One of our sponsors sells a pigtail for doing this
http://www.puredieselpower.com/catal...tail-p-99.html
