Lower steering column bearing
Old Dec 16, 2006 | 01:34 PM
HardFordCore's Avatar
HardFordCore
Hi folks, I need some help. I have a 71 or 72 steering column in my 66 F100 as part of a power steering conversion I did last year. The lower bearing in the column for the steering shaft has given up. Does anybody have a part number? Does anyone know where I can get one and has anyone removed the bearing without damaging the column itself? It is a little flimsy. Thanks very much.
Old Dec 16, 2006 | 04:04 PM
banjopicker66's Avatar
banjopicker66
I had the same problem with a '72 column in my '66. The "bearing" was a plastic collar with a center hole through it. The hole had wallered out quite badly.
I bought a replacement steel bearing from this guy on E-bay, and now I have silky smooth steering. It was easy to install, but you have to remove the steering column to do it.
He has one on E-bay now, Item Number 260065493702.
Old Dec 16, 2006 | 08:57 PM
HardFordCore
BP66,
Thanks for the lead. I slogged around the Pick and Pull this afternoon in Moss Landing, that's on the West Coast near Monterey, California. Found a new donor. A 71 F350 Ranger Cab/Chassis that was probably an RV, the RV part is gone. I removed the whole column which was in very good shape including the nuetral start/backup light switch. I will order the bearing you pointed me to be sure of a good repair. This donor truck also has Ranger bucket seats so I may return to liberate those for reupholstry. Thanks again.
Mark
66 F100 Custom Cab Styleside Shorty
Old Dec 17, 2006 | 06:56 AM
barry's Avatar
barry
Part number for the lower bearing is C3DZ 3517-A and the cone ia a B1AZ 3518-A. You can get them thru Ford or even NAPA. Just give them these part numbers to cross over. The most common reason they fail is the tube is worn, out of line, or you have cab mounts on the way out. Make sure the gap between the steering wheel and the lower hub or socket is not excessive, meaning any more that an 1'8 to 1/4 inch. if it is more then the cab is sagging and too much pressure is being put on the bearings, causing premature failure.
Barry
Old Dec 17, 2006 | 09:00 AM
seetwisted's Avatar
seetwisted
I don't have any experience with the column you are talking about...but on my 66 (after having the lower bearing sieze in a turn) I found that the lower bearing was/is an unsealed unit and that trash in the column built up in the bearing and ruined it. I found a sealed bearing in my "parts n pieces" drawer and replaced it.
Old Dec 17, 2006 | 12:25 PM
banjopicker66
Barry, I am not sure we are talking about the same bearing at the bottom of the column? ?
The '70s one I discussed earlier wasn't a bearing at all, it was a plastic plug in the bottom of the outer tube. It had 2 or 3 ears to clip into slots in the bottom of the column, and a central hole for the center steering shaft.
It was completely different from the ball bearing and race used in my '60s columns. The bottom of the earlier columns have a shaped metal plate, so to speak, with a formed cup to accept the bearing. This bearing is the same as used in the upper part of the steering column.
Old Dec 17, 2006 | 04:56 PM
barry's Avatar
barry
You're right. It's bearing D1TZ 3517-A. Bearing and retainer assy. I goofed!
Barry
Old Dec 18, 2006 | 12:22 PM
Daplumma's Avatar
Daplumma
Very timely post if I must say.I just bought one for the 1976 steering column I am installing in my 1965.Looks like a good idea.Did you weld or screw yours in?
Joe
Old Dec 18, 2006 | 02:06 PM
banjopicker66
Joe, I screwed mine in.
Did your '76 column have the lower plastic collar/bearing?
Old Dec 18, 2006 | 04:43 PM
Daplumma's Avatar
Daplumma
Yes,Its not the greatest design.I just changed the column on the 75 when I went to power steering and it also had that set up but wasn't that worn so I let it go.The one going in the 65 is all wallowed out and I dont want to do it twice.
Joe
Canus
Dec 12, 2012 10:06 PM
qwertyd10n
Jan 30, 2011 11:13 PM
73FOMO
13
Apr 11, 2006 11:48 AM
mechanicsburg
Nov 24, 2004 05:56 PM
