Steering column bearing removal?
Old Mar 19, 2006 | 05:18 PM
73FOMO's Avatar
73FOMO
How do you remove the lower bearing in the steering column? I already have the column and shaft out. Thanks!
Old Mar 19, 2006 | 11:19 PM
GeneStoner's Avatar
GeneStoner
If it is plastic, you should be able to break it off and out of the column with a pair of pliers.
If that offends your sensibilities, you'll have to remove the center (solid) column entirely from the unit (up by the steering wheel) and then slide it off of that solid column. But you will probably need to do that anyway when you install your new lower bearing...
Old Mar 20, 2006 | 04:58 PM
73FOMO's Avatar
73FOMO
Not sure if I follow you. I have the column and the inner shaft and spring completely out. The bearing is still in the bottom of the main housing, it doesn't slide off the column. It looks like it is in some sort of retainer?
Old Mar 20, 2006 | 05:25 PM
1975Ford's Avatar
1975Ford
Is the retainer plastic?
Old Mar 23, 2006 | 02:41 PM
73FOMO's Avatar
73FOMO
No. There is like a plastic race on the steering shaft itself, but the bushing/bearing is in the end of the main housing.
Old Mar 23, 2006 | 02:51 PM
Mil1ion's Avatar
Mil1ion
1975Ford's Avatar
1975Ford
It's been awhile since I messed with those bearings, If my memory correct, it should have a clip at the end so the bearing doesn't move., does it have the splines on the bottom of shaft?
Old Mar 24, 2006 | 12:19 PM
73FOMO's Avatar
73FOMO
Dennis,
The bearing is in the end of the steering column assembly...below the slot where the shift fork inserts. It must be built into the housing and non removable. It is not even shown on your exploded diagram. It is the bottom bearing that the steering columns turns on. The top bearing is shown, it is in the upper flange.
Old Mar 24, 2006 | 12:28 PM
Mil1ion's Avatar
Mil1ion
I know, I post the pic to show that they (FORD) don't show a bearing.
If the column had one, it should show up in an exploded view ...correct
Everything else is there
Maybe I'll do a part look up in my Fird Parts book ?
Old Apr 10, 2006 | 05:02 PM
73FOMO's Avatar
73FOMO
Dennis,
Any luck on the parts lookup?
Old Apr 10, 2006 | 05:34 PM
1975Ford's Avatar
1975Ford
73FOMO, check out national part depot, under the steering catalog, 3517 BEARING ASSY, Steering Column; 3518 BEARING SLEEVE, Steering Column Tube, they have what you're looking for.
Old Apr 10, 2006 | 06:33 PM
Mil1ion's Avatar
Mil1ion
This is a Mispost
Old Apr 11, 2006 | 08:14 AM
1975Ford's Avatar
1975Ford
Mil1ion, what is a mispost?
Old Apr 11, 2006 | 11:48 AM
Mil1ion's Avatar
Mil1ion
I posted the exact same info you before I saw your post.
I viewed it before logging in.
Then after I logged in and posted my info I saw and read your post, so rather than post the identical info, I typed in mispost because I can't delete the post or didn't have anything else to add plus, I needed 10 characters to make it happen
Fordication
Jan 5, 2017 07:25 PM
lowrider50
Aug 15, 2016 01:33 PM
vidaliaman
May 4, 2016 08:36 AM
R. Tovar
18
Nov 19, 2014 06:28 PM
fishmanndotcom
May 12, 2011 09:12 PM
