Trans temp while towing
Old Dec 15, 2006 | 06:49 PM
redave's Avatar
redave
Towing in traffic trans temp was 180, outside air temp was 56 degrees.
This truck only has radiator for trans cooling - no oil to air cooler.
The truck is 1999 F350 DRW towing 10,500 trailer weight.
Is that temp OK for such a low outside temperature?
Old Dec 15, 2006 | 06:56 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Think how high it will be at 90-100 degrees ambient. You need an aftermarket cooler, a Trucool should do nicely.
http://www.dieselsite.com/index.asp?...ROD&ProdID=205
Old Dec 15, 2006 | 06:59 PM
shenders99's Avatar
shenders99
My trans temp with 7K at 105 ambients can get up to 190 but that is pushing it very hard in very hilly terrain. Get a cooler or a mag-tech tranny pan, or both.
Old Dec 15, 2006 | 07:01 PM
Uzumati's Avatar
Uzumati
Where is your sender located? if it is on the output side of the tranny those numbers are fine but if you are using the test port like most people they do seem a little high. Ditto on Rampage's trucool suggestion.
Old Dec 15, 2006 | 08:05 PM
cangim's Avatar
cangim
I find it odd that you don't have at least a small Oil to Air cooler, did it not come with a tow package? Anyway, I am very happy with my Tru Cool as well. Ordered it from the same site listed above.
Old Dec 16, 2006 | 04:00 AM
AustinS's Avatar
AustinS
With what you have, that's not bad if output fluid temp.
Get a oil to air cooler and you're good to go.
Austin
Old Dec 16, 2006 | 10:41 AM
Casey's Avatar
Casey
That truck has been modified. When it left the factory it only had an air to oil cooler, and no cooler in the radiator. It really needs both.
Old Dec 17, 2006 | 08:55 AM
aklim's Avatar
aklim
My Ex has a line running to the radiator and then to the trans cooler. I have since replaced it with a 6.0 cooler.
The stuff you should be able to get from Home Depot in the plumbing section. The hoses are got from a trans shop or parts house.
Old Dec 17, 2006 | 09:19 AM
pops_91710's Avatar
pops_91710
180 degrees isn't all that bad. It's when you get into the 220 degree area. Nevertheless, I am a firm believer in auxiliary coolers.
Better ones have T-stats to keep the trans fluid at a minimum operating temperature to help dissipate condensation.
Big Vic
May 19, 2014 11:47 AM
1L243
Jun 18, 2011 07:21 PM
hdman6
27
Oct 3, 2008 06:44 PM
srauner
Aug 23, 2007 06:48 PM
nurse47557
1997 - 2003 F150
Jan 15, 2005 10:02 PM
