Towing in traffic trans temp was 180, outside air temp was 56 degrees.
This truck only has radiator for trans cooling - no oil to air cooler.
The truck is 1999 F350 DRW towing 10,500 trailer weight.
Is that temp OK for such a low outside temperature?
My trans temp with 7K at 105 ambients can get up to 190 but that is pushing it very hard in very hilly terrain. Get a cooler or a mag-tech tranny pan, or both.
Where is your sender located? if it is on the output side of the tranny those numbers are fine but if you are using the test port like most people they do seem a little high. Ditto on Rampage's trucool suggestion.
I find it odd that you don't have at least a small Oil to Air cooler, did it not come with a tow package? Anyway, I am very happy with my Tru Cool as well. Ordered it from the same site listed above.
