My local WalMart seems to have lost the SilverStar headlight conversion book. I was wondering if anybody knows the # of the bulb I will need to put in my 2000 F-350. There are 3 bulb packages that all look the same except with different part numbers. Thanks in advance!
Here ya go...and while I was at it...I just added the entire list of bulbs needed for your SD.
2000 FORD F250-F550 (With replaceable halogen capsules)
High & low beam headlamp
9007
9007SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9007ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9007XV XtraVision Halogen Upgrade: Up to 20% Brighter
9007CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9007LL Long Life Halogen Upgrade: Lasts 3x longer
Parking light
3157LL
Front turn signal
3157LL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
922
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
9145
9145ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
168
Back up light
3156LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
Glove box
161
Dome light
578
912
Step/Courtesy light
168
Trunk/Cargo area
906
Under hood light
912
Instrument-general
194
37
Check engine indicator
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
194
Directional signal indicator
194
I put in the Silverstars and wasn't pleased with the results. I think I might try the PIIA next. It just didn't seem to brighten it up a whole lot more.
is there a trick to remove the wire connector from the bulb
It IS a bother....
there's a plastic clip (that CAN be broken ) you have to lift and then separate the two...
mine took a screw driver to pull it apart even with releasing the clip...
i have a 6"lift with 37"tires and i have had the silverstars for about 2 months. I got'em because i wanted a brighter light but because my lift they don't really make a huge difference as to a normal vehicle height. but they might work great for you.
