Sylvania SilverStar
Old Jan 9, 2014 | 06:50 PM
RobertJohn's Avatar
RobertJohn
Exclamation Sylvania SilverStar
Which model of the Sylvinia SilverStar will fit my 1999 F250 Superduty ?
Are there any connection problems ?
I've read where the Ultra is even better.
Any help or suggestions ?
Old Jan 9, 2014 | 07:07 PM
F350-6's Avatar
F350-6
Should be just a standard 9007 bulb. Yes the ultras are worth the extra money since they do make a big difference over stock.
Old Jan 9, 2014 | 08:06 PM
white Buffalo's Avatar
white Buffalo
Same here, Ultra's is what I put in as well. Just plug & play.......easy install.
Old Jan 9, 2014 | 08:47 PM
arkredneck's Avatar
arkredneck
I just out in the piaa lamps nice improvement over stock
Old Jan 9, 2014 | 08:58 PM
Tact's Avatar
Tact
I've read in reviews that the life span is pretty bad. How long are these lasting before they burn out?
My stock bulbs are horrible and I need to make a change.
Old Jan 9, 2014 | 09:12 PM
arkredneck's Avatar
arkredneck
I read a lot of bad reviews on silverstars and piaa was rated much better
Old Jan 9, 2014 | 09:14 PM
SARDiverDan's Avatar
SARDiverDan
I have had mine in for a little over 4 years
Old Jan 9, 2014 | 09:23 PM
daddyusmaximus's Avatar
daddyusmaximus
I saw the PIAA ones at 4 wheel Parts in Indy. The guy said the SilverStars were as good and cheaper. My headlights suck. I switched them out last year... they still suck. I put in Sylvinia something... can't remember if SilverStar or Ultra. I'm thinking of adding a separate relay for them so they have a more direct current path. My '66 F100 (that I miss dearly) had headlights this good.
Old Jan 9, 2014 | 09:28 PM
white Buffalo
I've had the Sylvania Silverstar Ultra's in my F-250 for @ 6 years, and in the Excursion about 2.
Old Jan 9, 2014 | 09:47 PM
schlepprock250's Avatar
schlepprock250
On the topic of headlights,are the pigtails RiffRaff sells that converts our harnesses from the 9007 bulbs to the 9008/H13 bulbs an improvement? Are the 9008/H13 bulbs brighter?
Old Jan 9, 2014 | 09:59 PM
Bently_Coop's Avatar
Bently_Coop
Those pigtail adapters are for 05 plus headlights on 99-04 trucks or excursions.
Old Jan 10, 2014 | 09:51 AM
spongecop's Avatar
spongecop
Semper Fi
I have had the ultras for two years. Had the right side burn out after 8 months. I was told since they are an essentially hotter bulb they are more prone to burn out...especially if you are off roading at night. Since I use mine for a hunting rig from Sep-Jan I think that had something to do with mine.
Old Jan 10, 2014 | 05:20 PM
dn29626's Avatar
dn29626
From the Sylvania bar chart for "life of bulb" ( 4 bars is the maximum)
standard 4 bars
xtravision 2 bars
cool blue 2 bars
silverstar 1 bar
silverstar ultra 1 bar
Old Jan 10, 2014 | 06:02 PM
daddyusmaximus
OK, that sucks. What's a guy to do if he wants to be able to see the road at night?
Old Jan 10, 2014 | 07:07 PM
Ponyboychris's Avatar
Ponyboychris
My Silverstar's are at least 6 years old now.
