spedo
Dec 11, 2006 | 12:48 PM
spedo
does any one know where the spedo cabel goes on the trany of a 84 f150 i can't see any where to put it
Dec 11, 2006 | 02:05 PM
The speedometer cable hooks near the back of the transmission on the drivers side of the car. Just before where the driveshaft goes in.
It might help if you tell us if you have an automatic, or manual tranny, 2, or, 4 wheel drive!
Dec 11, 2006 | 04:50 PM
oh sorry i was in a hury. it is an auto with 4 wheel drive
Dec 11, 2006 | 05:57 PM
goes into the transfer case on the drivers side on a fourwheeler
Dec 11, 2006 | 07:07 PM
do you mean on the top of it because i can't see the area to put it
Dec 18, 2006 | 06:00 PM
there does not apper to be a place to put it in on the transfer case that i can see
Dec 18, 2006 | 07:30 PM
I guess I should ask the question. If you took it out or did it break? Look for a small 3/8 bolt I think that is what holds down the gear It is not in a very obvious place its up on top. If it broke you cant just slide it back in
Dec 18, 2006 | 08:02 PM
If the cable were broken off it would be very hard to see. When I last dealt with mine, I had to crawl under and stick my head up between the driveshaft and frame rail to see it well. I believe my '83 Bronco had an 8mm (3/16?) bolt and my '86 has a 3/16 (Allen wrench) cap screw.
Dec 18, 2006 | 08:25 PM
no it was not broken but when i purcesed it it was not hooked up
Crewcab Turbo
Oct 13, 2011 05:28 PM
mcgyver010101
May 2, 2010 04:30 AM
Mark DeDo
May 28, 2008 03:21 AM
Dennis690
Oct 16, 2004 02:10 AM
oilyowl
Dec 9, 2003 02:22 PM
