Speedometer not accurate.
Old Oct 12, 2011 | 08:42 AM
Crewcab Turbo's Avatar
Crewcab Turbo
My spedo is not accurate. I used my autoenginuity to try to correct it and now I'm 6 mph off at 55 and 65. Spedo reads high. What am I doing wrong? Do I have a bad sensor? Any advice? Thank you!
Old Oct 12, 2011 | 08:53 AM
frdf250's Avatar
frdf250
you need to go to the manufactures website for your tire. or go to tire rack.com find your tire and it will give you the correct outerdiameter size. post up what size your tires are on here and ill help you look
Old Oct 12, 2011 | 08:58 AM
Crewcab Turbo
Tires are 285 75 16 Kelly sifari Trex thanks
Old Oct 12, 2011 | 09:01 AM
frdf250's Avatar
frdf250
those are 32.8...so 33" should be fine what did you enter
Old Oct 12, 2011 | 01:58 PM
Crewcab Turbo
I put 31.5 in , that's the height of my tire with it on the truck. I will try 33 when I get home in a half hour. I forgot the laptop at home. Thanks!
Old Oct 12, 2011 | 02:24 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Crewcab Turbo
I put 31.5 in
I have the same size tires and used 33.25 (AE Version 8.2.1) and the speedo matches my GPS exactly.
Old Oct 12, 2011 | 03:47 PM
Crewcab Turbo
I made the change to 33.25 and it's off more now! Now it reads 8 mph faster! What could it be?
Old Oct 12, 2011 | 03:58 PM
PaysonPSD's Avatar
PaysonPSD
There isn't some type of speedo correcting devicw already on the truck is there?
Was the speedo accurate with the previous tires.
Old Oct 12, 2011 | 04:57 PM
Crewcab Turbo
It has been off since I owned it . I have had the same tires always.
Old Oct 12, 2011 | 05:02 PM
PaysonPSD's Avatar
PaysonPSD
Seems like the AE adjustments are going the wrong way. Try the smallest tire available in AE and go from there. That's all I can think of.
Old Oct 12, 2011 | 05:44 PM
frdf250's Avatar
frdf250
what are you using to compare it...?
Old Oct 12, 2011 | 07:04 PM
Crewcab Turbo
I'm using my gps think it's a garmen to judge my actual speed. I'm not sure about a speed adjusting module? I never thought to look for one. Is the speed sensor on the transfercase? Other than being under the truck by the speed sensor, is there another common spot where it could be? Also I hooked up my autoenginuity and the readout for speed was accurate with the speedometer, so I will look for a little box wired in somewhere.
Old Oct 13, 2011 | 05:28 PM
Crewcab Turbo
Ok I looked under the truck and under the dash and under the hood the only non factory item I found is what I think is a gps transmiter, a black box aprox 2" square and a quarter inch thick. It's above my spedo cluster, it has power going to it, a yellow wire streched out for an antenna I would assume. it also has a blinking green light. I cannot find any spedo correction device. Also I don't know where the speed sensor is! Is it in the transfercase? Does the speed sensor have a gear on it that could have been changed? What could be my problem? My spedo being off drives me nuts!!! Plus im sure it effects the computer some how being off? Please help! You people are awesome! Together we can do it!!
F150vettehauler
2004 - 2008 F150
May 5, 2014 01:58 PM
TXHillCountry
Mar 15, 2007 02:51 PM
75 SuperCab
Aug 28, 2006 03:18 AM
Nightrain
Jan 29, 2006 02:36 AM
slntnddly
Mar 8, 2004 02:58 PM
